She runs....just the damn BMW fan switch (new) isn't working correctly. There is no low temp turn on.
New sitch in the way. Then hooked up the MSD stuff (requires swapping dizzy to gutted one) ...NO FIRE!!! ARGH. Went trhu dizzy alignment 3 times. NO FIRE ..AND starter (new) is starting to drag. discovered end of cable (00 welding cable) was not in good shape...so cut end off and add new, reinstall.Starter problem fixed. Seems I smoked the hei coil.. argh. Dig up another coil, install, STILL NO FIRE. ARGH ARGH. un-hook MSD (just unplug it from dizzy and remove ground wire) re install regular dizzy... FIRE and runs. Was just about to REMOVE MSD box (power and IGN wire are soldered in to harness) toesnd out for troubleshooting-repair) when I looked at wiring diagram.. AGAIN (yes I have the ORIGINAL paperwork from 1991) AHHHHHH I see WTF my brain overlooked. I hooked it up WRONG (this time). It does NOT get a jumper from ignition wire to BATT on the coil. Hooked it up CORRECTLY...all works as designed...it runs! Re-set timing check curve, good start point 16* initial 34 total all in around 2400. Tidy up the loose wires with some very cheap and useless Chinese spiral loom. ARGH...can't seem to buy anything worth a crap anymore! Next up...solenoid and relay HARD mounts in the trunk (never did mount them before).
So recap: finish some hard mounts to allow tidying up wiring. re-install drivers seat. INVENT some kind of breather assembly to fit the HOLLEY AND allow us of my shaker. Confirm fan operation.
