1981 Camaro Z28 / Backfire, loss power, no start
Jan 28, 2023
54
HELP! Got my 81 camaro z28 back and it backfired from carb, lost power multiple times on highway and now wont start. Eventually from stop to go, it would only roll with WEAK POWER foot on accelerator hard. NOw im parked, and i get one click of starter, but no start…. What would cause the backfire then loss of power, now no start??? And now not even start? New battery, new starter, new carburator… this was happening before i added these parts and after… please help!!!! Stock camaro z28 350 (no smog). We thought torque converter cable housing was sticking to cable, it was, fixed the sheath around it, but still…. Now wont even start. Lights work “not battery”. HELP ME PLEASE?
hubedobeedo
3rd times a charm
Jul 18, 2013
1,186
Huntertown,IN
sounds like more than 1 problem. Curios you just got back from where? if it backfires though carb check for timing issue could be distributor needs adjusted .no start, check your wires for ignition and battery. There is a wire from battery to core support junction i believe, that will cause a no start but still have lights. Check your grounds.
Jan 28, 2023
54
Back from a mechanic. 40 miles drive. Brand new starter, but it just clicks now. Maybe bad starter again? Will check distributor, timing is advanced i believe 112.
23,530
The Moon
Check the connections at the starter and battery. The thinner gauge wires at the starter near the exhaust heat will deteriorate.
tom3
15,810
ohio
Pull the headlights on, hit the starter. If the lights stay bright the battery cables are probably ok. If they go out and stay out there's a problem in the main cables.
