1981 Z28 4spd, needs some TLC
Discussion in 'Camaros for Sale' started by Guppy80, Dec 10, 2018.
  1. Guppy80
    Guppy80 New Member
    9
    Dec 8, 2011
    New Jersey
    Unfortunately I have run in to quite a few things and I am having to let my car go. There are good and bad things about the car, but it can become much more if given the time. I would be looking for around $5,000 or best offer. If you would like more pictures, please let me know, and ask any questions you would like.
    The Good;
    New Blueprint Crate 383 (roughly 4k miles on it) [$4,000 crate enegine]
    Fully rebuilt, all new internals Borg Warner Super T10 4spd filled with Royal Purple (about 6k miles on it)
    New Clutch/Flywheel (roughly 4k miles on it)
    MSD Atomic EFI system [$2,500 Hybrid Carb/Fuel Injection system]
    New Fuel tank
    New Sending unit
    Hotchkis TVS Stage2 tubular full suspension with sub-frame connectors with modified front adjustable suspension [$4,000 suspension kit]
    MSD 6AL Ignition box
    New Door hinges and outer door handles
    New Heater/Vent fan
    New High output performance alternator
    Dual 6,000 CFM electric radiator fans
    The Not so Good;
    Single-plane stock 350 Radiator (triple plane aluminum Griffon performance radiator was damaged by mechanic.)
    Exhaust manifold gaskets need replacing
    New Painless full wiring harness needs replacing (Mechanic spliced the wiring harness to try and match factory harness)
    Needs A/C harness
    A/C needs recharge
    Needs Front, Rear, and all weather seals replaced
    Rear Posi-Traction will not engage (power goes mostly to Right Rear tire)
    BFGoodrich Radial T/A might need replacing due to age (Roughly 4 to 5 years old now)
    Rear View mirror adhesive came off
    Was bumped in right rear quarter and needs some body touch up
    Driver and passenger seat rails need replacing/rewrap
    carpet needs replacing
    image1.jpg image2.jpg image3.jpg image4.jpg image5.jpg image6.jpg image7.jpg
  2. Popper
    Popper Veteran Member
    101
    13
    Mar 24, 2018
    PM sent
  3. Guppy80
    Guppy80 New Member
    9
    Dec 8, 2011
    New Jersey
    Adding pictures as requested.
  4. Jerry SS 396
    Jerry SS 396 Veteran Member
    250
    Nov 2, 2008
    NORTH JERSEY
    Is this car still for sale?
