1LE Front and WS6 Rear Brakes with Manual Master Cylinder?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Jon Randolph, Jul 25, 2018.
  1. Jon Randolph
    Jon Randolph Member
    85
    May 22, 2017
    Barrington, IL
    I just purchased a master cylinder from PTFB and am curious to see if anyone has tried running manual brakes with the 1LE front setup? Anyone try running manual? How do you like it? Any tips?
    I also just bought a pair of '79-'81 disc brake WS6 backing plates this week.
  2. dale68z
    dale68z Veteran Member
    1,398
    36
    May 14, 2009
    Peoria Arizona
    manual master cylinder is a 1" bore, so your pedal travel will be longer than a larger power brake 1 1/8 master. Your manual master will build more pressure with less foot pressure, though.
    Should work well.
  3. Jon Randolph
    Jon Randolph Member
    85
    May 22, 2017
    Barrington, IL
    I just spoke with Dave from Pro-Touring F-Body again yesterday about a cheap option for the rear WS6 backing plates. The Wilwood setup he sells looks awesome but for my current budget, he said I could put on G-Body calipers real cheap.
    From what I can tell, this would eliminate the problematic ratcheting parking brake.
  4. Skip Fix
    Skip Fix Veteran Member
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    GM "metric" D154 calipers are bolt ons. You do have to mess with the flex hose bolt on some as it is different than the WS6 ratchet caliper. I did that on the Camaro/IA project. DSC_0189.JPG DSC_0190.JPG DSC_0187.JPG
  5. 1973typeLT
    1973typeLT Member
    40
    Jul 22, 2013
    sacramento ca
    I did it the 1le swap and did a c3 vette manual mc and it works great. I don't have the ws6 rear though.
  6. 79T/Aman
    2,628
    246
    Oct 7, 2004
    Dickson TN.
    G-Body calipers also referred to as GM-D154 or "metric" calipers.
  7. dailycruiser81
    dailycruiser81 Veteran Member
    207
    10
    May 19, 2013
    ft lauderdale
    Be careful. I ordered the part number He gave me because He was out of red at the time from another vendor. Long story short they don't fit. They only except .81 thick rotor and the trans am rear you can only get. 9
  8. dailycruiser81
    207
    10
    May 19, 2013
    ft lauderdale
    What application are these for when you order?
  9. Skip Fix
    2,217
    25
    Mar 21, 2007
    Katy,Texas
    Late 70s early 80s Malibu. Right side.
  10. Jon Randolph
    Jon Randolph Member
    85
    May 22, 2017
    Barrington, IL
    Where did you get your numbers from?
    This is a selection I got from Rock Auto...
    Front rotor for 80's G-Body, S-10, F-Body, etc. ​
    Discard Thickness (IN) 0.96
    Nominal Thickness (in) 1.04 ​
    79-81 Firebird WS6 Rear Rotor...
    Discard Thickness (IN) 0.91
    Nominal Thickness (in) 0.97​
