2.41 posi to a 3.73
Discussion in 'Transmission & Driveline Topics' started by 80's AL, Sep 29, 2018.
  1. 80's AL
    80's AL Member
    72
    21
    Sep 23, 2017
    Dallas, GA
    how much of a PIA and $$$ is involved?
    i thought they make a thicker ring gear for these.
    or is it better to just find a 3-series carrier and change it out?
  2. 1980RS
    1980RS Veteran Member
    4,975
    1,512
    Jun 17, 2006
    MN
    I think the spacers will work with any gear set but you would just have to try it. It would be easier to get a 3 series carrier some gears and set it up once. It will make a noticeable performance change. Down side, lots more RPM on the highway.
  3. big gear head
    big gear head Veteran Member
    6,396
    171
    Jul 30, 2001
    Central City, Ky.
    The 2.41 uses a 2 series differential and the 3.73 uses a 3 series. There are no thick gears for the 8.5 10 bolt. If you are going to use the 2 series then you will have to use a spacer, which I don't recommend.
    RS1979 likes this.
