Todd Devine
- Aug 6, 2021
- 25
I just finished a year long 70 Z28 build and have questions about gear ratio.
The car was a father/son project that sat for about 10 years before I purchased it. I am not sure if it is a real Z28 as I don’t have a trim tag and it was a Los Angeles built car.
It has a CTB stamped block with 186 camel hump heads, and an original polished winters intake. The trans. Is a Muncie close ratio 4 speed. Also has a floor mounted gas pedal.
The rear end I am assuming is not original to the car and is a 10 bolt open rear end. I calculated the rear gear ratio at about a 2:73 as it is revving about 2500 rpm at about 65 mph.
My question/ issue is it is a complete slug off the line and needs a good amount of RPM to take off from a stop. Once moving it seems to go pretty good.
Is a 2:73 rear not compatible with the Muncie gearing?
I do plan on changing the rear to a 3:55, or 3:73 with posi. Would this make a huge difference on acceleration from a stop?
