2005 Silverado water temp\heater?
Discussion in 'The BS Topic' started by FatnLow, Oct 31, 2014.
  1. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    In my pickup 5.3 when I turn AC on temp will go to middle bar between standard 210 and 260 and it will not heat the interior. Is there some valve controlling this water? I turn it off and it will drop back to 210. This morning though when I kicked it in to get on interstate the mystery valve popped open and heat started. Or could this have just been caused by more air cooling engine. I appreciate any feedback.
  2. Joekool
    Joekool Veteran Member
    5,922
    35
    Feb 4, 2002
    Hollister CA USA
    Have you checked the coolant level? The first thing that will be affected by low coolant is the heater core.
  3. Leonards78LT
    Leonards78LT Veteran Member Lifetime Gold Member
    1,031
    Jan 21, 2001
    Central Oklahoma
    ^^^^^^ +1
  4. FlaJunkie
    6,417
    246
    Mar 24, 2001
    Rockledge, Florida
    My 2001 has water circulating all the time. A valve allows air to cross the core.
    Has it had a coolant flush recently? This can cause heating issues.
    Also check for cracked radiator tanks.
  5. gordonquixote
    3,022
    11
    Jul 18, 2006
    Tallahassee, FL
    +1 to low water
  6. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    OK Thanks all. I looked the other day. Just a minute.........I guess I'll start with adding more Dexcool. I'll report back later. btw I'm giving myself an epic facepalm right now.
