2005 Silverado will not talk to obd tool
Discussion in 'The BS Topic' started by FatnLow, Oct 30, 2012.
  1. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    I have a check engine light on my 1500 and autozone and advance cannot connect to it. They say check all fuses. I saw the ecm fuse it wasn't blown any tips greatly appreciated. Thanks Kent
  2. GMPARTS 1
    GMPARTS 1 Veteran Member
    427
    Jan 9, 2004
    Va.
    Damaged terminals in diag port.
  3. John Wright
    15,166
    385
    Aug 9, 2002
    Rustburg, Va
    How old is their scanner? I tried to read the codes in my wife's 2008 and my scanner would not link up. However, I borrowed a newer scanner from a buddy and it reads it just fine. My older scanner would read my 04' truck's computer without any problem, linked right up, but not the 08'.
  4. Knuckle Dragger
    16,297
    2,634
    Nov 2, 2002
    Waddell AZ
    Did you check all fuses?? You mention the ECM but generally it's not the ECM fuse that causes communication issues.
  5. gramps
    gramps Veteran Member
    1,739
    1,197
    Jul 5, 2009
    mankato, mn
    Code readers need updates to keep current.
    Also, the ECM fuse is for the computer, not the power supply for the obd port.
    Check the cig lighter fuse.
  6. FatnLow
    1,954
    Mar 12, 2003
    Montgomery, AL US
    Cig lighter fuse was blown. I'll Keep checking all others also. I'll try again. Thanks
  7. 496z28
    496z28 Veteran Member Lifetime Gold Member
    967
    8
    Sep 23, 2007
    Oklahoma City
    ALDL is powered by cig lighter fuse...
  8. greencamaro1981
    greencamaro1981 Veteran Member
    604
    Jun 2, 2010
    Montana
    yes silverados are very finicky
  9. JONESYFXR
    JONESYFXR Veteran Member
    2,177
    Oct 10, 2009
    BUFFALO, NY
    Used your pcm is crap, that would cause it not to connect too.
  10. dirtmod08
    1,953
    549
    Jan 17, 2007
    Central Illinois
    I would start off with a new oxygen sensor.:D
