Brian Anderton
- Jan 1, 2022
- 12
I just talked to Phillip at Howell a few minutes ago. He told me pretty much the same thing. I'm going to wait 'til I have the motor in my possesion, buy the camshaft and springs, throttle body (cable) and then call them again with my setup. I will make sure my transmission (T56 wide ratio 6 speed) and 3.55 rear gears are available first also. That is my plan. And I will also have the ECM control the cooling fans either on or off (not PWM). 205 on 195 sounds a little narrow to me. I might widen that a bit. 73Z how often do you fans cycle on/off?
