2010 camaro ss calipers how to fit to 2nd gen spindle of cpp c5/c6 new spindles
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by whitelemmo, Jan 25, 2013.
  1. 79T/Aman
    2,628
    247
    Oct 7, 2004
    Dickson TN.
    you da man than;-)
  2. $ Mike 70 Z-28
    $ Mike 70 Z-28 Veteran Member
    1,250
    126
    Nov 7, 2002
    New York, NY
    I saw you posted pics of your brake swap. from where did you get the parts to do this swap..? like brackets and stuff
  3. Bonz10
    Bonz10 New Member
    13
    Apr 5, 2020
    mike
    cpp spindles for the c5 brake conversion
    cpp spindles
    you will need to make a wheel spacer and use longer wheel studs
    you will need to open the the center hole on the 2010 camaro rotor to match the hub dia
    look up lukestaff.com he has a loot of information and and bracket designs
    $ Mike 70 Z-28 likes this.
  4. $ Mike 70 Z-28
    1,250
    126
    Nov 7, 2002
    New York, NY
    THANKS bro i will look in to this
  5. BBU.COM
    BBU.COM New Member
    May 1, 2021
    Hi Everyone,
    I joined to post this, I have tooled my mill to work the C5 Spindles to use the brembo calipers correctly. I had brackets laser cut and standoffs turned to exact tolerances. These can be utilized with C5/C6 or C7 hub bearings. Right now it looks like the pandemic is slowing production of the CPP C5 spindles but if anyone wants to convert to the brembos that already has these spindles I`d be happy to help them.
    https://bigbrakeupgrade.com/2021/03/06/tall-spindle-guys-inside/
    Zulu28 likes this.
  6. $ Mike 70 Z-28
    1,250
    126
    Nov 7, 2002
    New York, NY
    Do you have complete kits for front and back ??
  7. BBU.COM
    BBU.COM New Member
    May 1, 2021
    HI, Typically yes I do, the CPP spindles are covid back ordered and the park brake backing plates are back order from GM right now too..biggest problem is stock for these and several other normal items, ARP studs- I have two numbers I use usually and both have been out of stock everywhere for months...everybody is buying, nobody is working !
    rear for the early 10-12 bolts https://bigbrakeupgrade.com/product-category/rear-brakes/early-10-12-bolt-8-28-5/
  8. Zulu28
    Zulu28 Veteran Member
    299
    26
    Dec 19, 2013
    Vancouver, BC
    Nice upgrade and the cpp spindle is not a dropped spindle which works for me.
