2018 Cadillac 6.2
Discussion in 'High Tech Retrofits' started by ultimateoffroad, Oct 25, 2020.
  1. 73Z L92
    73Z L92 Veteran Member
    255
    97
    Jan 25, 2011
    Carlos, MN
    I did a 2012 6.2/TKO 600 into a 73 Z28. It was a great swap.
    On the Gen V LS engines you have to add a power steering via the after market. Your 2018 6.2 has electric power steering. Also it should have VVT and DOD so you need to decide to keep or delete. Some keep the VVT but most delete the DOD do to some lifter failures.
  2. Fme
    Fme Member
    80
    15
    Apr 23, 2013
    USA
    You will need a .400 thicker flywheel that only McLeod sells amongst a host of other things.
