Wow! and I have several people bitching about my price on one of the 468 BBC's $4500 I had for sale as a complete engine carb to pan.As with everything quality machine shop prices have gone up. Prices from Holbrook Racing Engines outside Detroit.
Bore & Hone up to .030″ oversize $500.00
Bore & Hone up to .080″ oversize $700.00
Bore & Hone over .080″ oversize $800.00
Bore & Hone over .100″ oversize $875.00
With Torque plates – add $250.00
Touch hone ONLY $250.00
Touch hone ONLY w/Plates $350.00
Hone to specified size $400.00
Install Sleeve (includes sleeve) $275.00
Deck Block, Clean up only $225.00
Deck Block, Parallel Cut $250.00
Measure & Check main bearing bore alignment $80.00
Align hone main bearing bores – 2 bolts $300.00
Align hone main bearing bores – 4 bolt / cr. bolt $350.00
Align hone main bearing bores – studs or girdle $400.00
Cut block deck for receiver grooves, V8 $300.00
Magnaflux Block $150.00
Sonic Check Block $275.00
Weld caps to restore register $150.00
Install Cam bearings & plugs (plus parts) $80.00
Three angle valve job is $450.00 a pair
