Probably just store it in the garage.so you are planning on saving the oe engine in a crate ?
I am retired but my guy Tom is running our website. crateenginedepot.com GM crate engines. He knows whats up and is a straight up honest guy. Give him a calll and he can guide you along. Good luck with your build.It’s been a while since I’ve posted anything on here. In fact, the last thread I had going was very similar, but life took over (baby) and so I had to put it off. Now I’m getting the itch again after having saved up some money. My coworker has a 400 from a truck sitting in his backyard he’d be willing to sell. He also has a 327, and I’m tempted to build a 8000+ rpm motor out of it.
Last time, I had my mind set on just going with a Blueprint 400 sec and calling it good. Now, in late 2022, they seem to cost a couple thousand more than they did a few years ago. This also makes me believe machining costs have gone way up, so finding my own 400 and building it myself, like I want to do, will be just as, if not more expensive. Both of these factors make the higher cost of doing a complete LS3 swap seem not so high any more.
Anyone have any sage advice? Take these points into consideration (I want, at least, 2 out of the 3):
1.) I’ve never built and engine, and I REALLY want to take this opportunity to make that happen.
2.) I’m saving up to buy a home… in 2022… in California, so budget-friendly is a huge factor.
3.) I want to reliably make 450-550 hp, capable of 7000 rpm, and plan to use it mostly for autocross, but still want streetability.
yes, hypers are cast --- and their hypereutectic alloy is more brittle than and expands less than typical cast alloy. Hypers' minimal expansion can accomodate a tighter fit in bore & adjunct improved sealing.Biggest problem I had ( 302 ford) with crate engines were they all had cast pistons... LOTS of money for cast piston engines just didn't float my boat.. For forged pistons it was HUGE money.......
And Hyper pistons are CAST........
Destroking a 400 is what really has me enticed, honestly. I heard the 400/406 is better to build than a 377, but a 329 sounds unique and fun.
I’d really rather not do the LS. I want to keep this car carbed and leaf-sprung. It’s fun competing well with or besting the big-budget CAM cars.
I originally wanted to do a 377, but from all the research I’ve done on 377 Vs 400, everyone says go for the 400, even the old 377 guys.A destroked 400 to 377 is much better than a 400 build especially for auto cross that requires constant high RPMs. Using a 3.48 inch stroke and 6 inch rods will give you a 1.72 connecting rod ratio. Much better for high RPMs than the 400s 1.48 rod ratio and just shy of the 327s 1.75 rod ratio. There are a couple of benefits a 377 has to offer that have been lost in our current stroke everything modern hotrod mentality. Rod ratio is the biggest one. Not having the oil control ring going through the piston pin, being able to use big valves, and grinding down the combustion chambers giving the valves room to breathe in those big bores too. Use total seal rings and a oil separator/catch can for oil control. You’ll rev up much faster than any stroked combination and the engine will last longer too. I had a thought to add. A 3.25 stroke with a .030 overbore is 352. With 6.2 rods the rod ratio is 1.91. That’s nascar and Smokey Yunick territory.
