235/70/15 or ??? On 81 z
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by largestar, Mar 26, 2018.
  1. largestar
    largestar Member
    49
    9
    Nov 21, 2017
    I used the search function and read all the posts. Does anyone run 235/70/15 or 245/60/15 in place of the 225/70/15 that came factory on my 81 z? I have the five spoke factory wheels. Does a 255/70/15 on rear look ok? Pictures or comments please. I’m thinking b f Goodrich radial ta’s. Thanks
  2. CorkyE
    11,313
    877
    The 245x60x15 seems to be the go to tire for these cars if you're staying on a 15" wheel. I ran 235x70x15 for several years and did get some minor rubbing issue in the front.
    largestar likes this.
  3. Z28SSRS
    Z28SSRS Veteran Member
    190
    22
    May 2, 2009
    Nevada City, CA
    I've used both 245/60/15 and 235/60/15 all around on my '78 Z28 on the factory wheels. The 245's rubbed ever so slightly on the front at full lock on the inner part of the fender liners.
  4. Zspoiler
    Zspoiler Veteran Member
    4,004
    445
    May 6, 2012
    Federal Way, Washington
    When I bought my 1979 Z-28 RS P235/60/15 all away around on Appliance 15 x 7 'Turbine" wheels. I later put P245/60/15 in back.and no issues .And if you have any issues with rubbing in the back.You can always bend in the lip.
  5. largestar
    largestar Member
    49
    9
    Nov 21, 2017
    I want to run 235/70/15 all around, but not if it rubs on every bump. I like the slightly taller and wider tire. With an overdrive I don’t want a shorter tire. Maybe if I saw a pic of 245/60? Was the rubbing with 235/70 on turns or driving? It’s only 1/2 an inch wider and taller.
