285/35/18 on the front?
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by sunkenloot, May 26, 2015.
  1. sunkenloot
    sunkenloot Veteran Member Gold Member
    221
    Aug 30, 2010
    Dallas, TX
    I have seen a few threads where folks have said they did this but cant find images or any follow ups if they had problems.
    Think this would work on 9.5" rim with 5.75" BS?
  2. Lowend
    16,629
    1,355
    Mar 25, 1999
    San Jose, CA, USA
    In my experience, that's too big for the front, the tire will hit the rear of the wheel wells under load. 5.5" is the most backspace I've seen in front (albeit on 17" wheels) it starts getting REALLY close to suspension components
  3. dcozzi
    dcozzi Veteran Member
    4,335
    1,330
    May 1, 2002
    Phoenix, AZ
    I always wondered how big a tire if you removed or modified the inner fender. I am planning a 275/40/18 for my car one way or another. I think cutting out the inner sheet metal then welding in a "tub", so to speak, where the tire hits.
  4. Z-WIZZ
    Z-WIZZ Veteran Member
    1,297
    Mar 18, 2004
    FLA
  5. sunkenloot
    221
    Aug 30, 2010
    Dallas, TX
    Mainly this all came about because I found a style of rims I like and they are offered in 2 sizes only.
    I need to run same size front and back.
    the two sizes are
    18x9.5 w/ 5.75bs
    and
    18x8.5 w/ 4.5bs
    I think I could get away with 275 on the 8.5 but, didnt want to leave anything on the table.
  6. RS1979
    4,055
    967
    Jun 18, 2013
    Memphis, TN
    That's big. What size rear tires would you run if those will fit?
  7. sunkenloot
    221
    Aug 30, 2010
    Dallas, TX
    The same size, the goal would be to run matched sizes front and back.
    Its likely too much but, wasnt sure if the 275 would work on the 8.5 with 4.5 BS as I think the guys that do run those have a tick more BS, like 4.75.
  8. woody80z28
    5,633
    121
    Sep 8, 2004
    walton, ny usa
    That's basically what I did. I did it less for max width and more for maximum tuck. Same idea though. Rolled the outer and cut up the inner for clearance. Then added a 90* strip to the outer and added metal to the inner to mount the two back together for structure. This tucks a 255 tire by several inches. More pics in my thread.
    http://nastyz28.com/forum/showthread.php?t=112836&page=26
    This pic shows where the strip got welded to the outer.
