Project-Z28
I just picked up a good use carrier it came with a set of 3.42 on it . But I have a set of 3.73 gears as well . Which would be better for an all around street and sometimes strip car ?
Randy S said:What size tire are you planning to run? Do you have a target RPM for say, 70MPH? Does the wear pattern on the 3.42 ring and pinion look ok?
I'm running a tire that's right at 27" tall and wanted to be around 2200 RPM at 70MPH, so I'm running 3.42's.
Double J said:I have 1972 Camaro 3:42 gear M20 4 speed 26" tires taching at about 2600rpm at 60 mph. Great combo the M20 gets the car out of the hole quickly and the 3:42 does not tach to high at highway speed.
Highly Recommended............
