3.42 or 3.73 ?
Discussion in 'Transmission & Driveline Topics' started by Project-Z28, Aug 14, 2014.
  1. vfitom2aol.com
    vfitom2aol.com Veteran Member
    3,698
    Mar 2, 2000
    NE PA
    On my 70 to 74 Z28's with original, stock sized tires, with 3:73 gears, my speed was at 60MPH and taching at 3000 RPM.
  2. slayer74
    slayer74 Veteran Member
    166
    Jan 10, 2014
    yonkers new york
    no offense to you rich,but jersey highways are down right dangerous,people drive like maniacs
  3. BonzoHansen
    20,753
    1,814
    Jun 1, 2005
    Scott from Hamilton, NJ
    ^^as if NY is better! lol
  4. slayer74
    166
    Jan 10, 2014
    yonkers new york
    yup
  5. ULTM8Z
    ULTM8Z Veteran Member
    10,059
    868
    May 19, 2000
    Los Angeles
    Problem is you'll get rear ended doing "only" 60 on the highway.
    I'm routinely cruising 75+ just to keep up with the middle lanes. I could go in the left lane and do 80+, but I'm not in that big of a hurry...
    3.42's. Albeit with OD, but even around town the 3.42's are very nice.
  6. twozs
    twozs Veteran Member
    8,817
    172
    Aug 5, 1999
    hopewell jct ny
    Have you ever driven 684 or 84 . I got moms in mini vans passing me at 80 + mph . Its 4 wheel insanity . The taconic parkway is worse .
  7. Project-Z28
    Project-Z28 Member
    81
    Apr 22, 2012
    Newfoundland
    I'm running a 255/60/15 in the back and a th350 . I put the 3.73 in tonight . Used the spacer out of my 2.52 and it's way to tight . Going to have to pull it apart again and remove the shim . 0 back lash ! Lol . Any good links to doing rear end shimming , I know very little about it . :(
  8. Dogwater
    Dogwater Veteran Member
    926
    Dec 23, 2010
    SanAntonio Tx
    Your going to need some shims for the carrier an for the pinon.You can order them or a auto parts might have a shim kit. If your in a hurry like I was I went to the local pick n pull an walked around looking for where other people pulled apart the rear ends an left the shims behind. Some were laying on the ground others still stuck to the axle. Ended up with about 12 carrier shims, pinon shims, didn't find to many of those. You'll need a dial caliper to measure thickness also. Out of the 12 one was perfect an another I had to flat sand about 2 thousands off of it.
  9. doublec
    doublec Veteran Member
    1,977
    Dec 18, 2011
    Harrisburg, Pa
    if you have OD I would go 3.73 ( or a little deeper) all day long. I have 3.55's and just put a 700r4 in my car and wish I had more gear.
  10. Todd80Z28
    11,857
    424
    Jun 11, 2002
    Northern VA
    I tend toward the 3.42s.
    I run 3.42s with 26" tires and a T56 with 0.5 6th gear. I loaf along at 1500rpm at 65mph.:)
