302 aluminum intake?
Discussion in 'Engine Topic' started by Pete55, Dec 6, 2021.
Tags:
  1. Pete55
    Pete55 New Member
    Dec 6, 2021
    I just bought a 55 Chevy pickup with a locked up 350. It had been sitting outside since 97. The man that built it told me the intake manifold i IMG_20211206_155740082.jpg IMG_20211206_154103220.jpg s off a 302 z28 camaro. How can I tell? What's the value on something like that?
  2. INSPECTOR57
    INSPECTOR57 Veteran Member Lifetime Gold Member
    508
    45
    Sep 14, 2007
    Stillwater, Oklahoma 74075
    That is a 69 Z/28 intake, value is dependent on condition. Pitting around the water ports and t-stat housing are usual issues. Has the center divider been modified? Get it off and cleaned up and post some pics.
  3. Pete55
    Pete55 New Member
    Dec 6, 2021
    Would it hurt its value to have it bead blasted? Looks to be in great shape just dirty
  4. INSPECTOR57
    508
    45
    Sep 14, 2007
    You can use glass beads, not too much pressure though. Avoid the machined surfaces as aluminum erodes easily - use Scotch Brite pads there. Clean the oil and grime off first.
    Pete55 likes this.
  5. 70lt1z28
    4,570
    1,142
    Oct 3, 1999
    Beavercreek, Ohio, USA
    I would look into vapor blasting aka vapor honing. Really deep cleans the aluminum without messing with the surface texture. Motorcycle restoration guys have been using it for awhile and its now getting to us car folks.
    Rosster and Pete55 like this.
