350 ID Question
Discussion in 'Engine Topic' started by fish2222, Jun 5, 2020.
  1. fish2222
    fish2222 New Member
    Jun 5, 2020
    Hi guys. New here, but have had this engine for probably 15 years. It is a 3970010 with the 10 dot clock right next to it on the rear flange, so I am guessing is a Saginaw cast block. The only issue is that I can't find any ID numbers on it except that. The pad in the front on the passenger side is a lot smaller than any other engines I have seen and even though the numbers could have been machined off at some point, it doesn't seem to even be large enough. Any ideas where any other number may be? I have checked on the area behind the oil filter on the outer edge. I attached a picture of the pad in front of the passenger head just so you can see what I am talking about. Thanks.
  2. fish2222
    fish2222 New Member
    Jun 5, 2020
    Here is the clock. It also has 3917291 heads on it, which seem to be 68-69 heads.
  3. fish2222
    fish2222 New Member
    Jun 5, 2020
    I did just happen to be looking on Ebay just for pictures and found some later 70's blocks with the smaller pad, so maybe that's what it is.
  4. 79RedZ
    79RedZ Veteran Member
    757
    67
    Mar 24, 2009
    Hamilton,MI
    That size of pad would indicate that it’s a 1977 up block.
  5. 87 Eddy
    87 Eddy New Member
    Jun 14, 2020
    New to the site looking for help deciphering code on My Block at the back of the block it has 5.7 and no casting number front of the block behind alternator it has V0810PLB any help would be greatly appreciated
  6. Gary S
    23,344
    1,240
    5.7 is metric for a 350, but metric didn't show up until well after Second Gen Camaros. That code probably won't show up on the old lists. Try some site that lists codes for newer vehicles.
  7. 87 Eddy
    87 Eddy New Member
    Jun 14, 2020
    Ok thanks
  8. Gary S
    23,344
    1,240
    The only PLB code I've been able to locate so far is for a 1988 454 truck engine. That doesn't help you. I can't find much information on codes for newer engines.
  9. 87 Eddy
    87 Eddy New Member
    Jun 14, 2020
    That was the only one I found too....thanks for looking
