350 short block build help
Discussion in 'High Performance Modifications' started by slamdik, Nov 21, 2007.
  1. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    vvv
  2. thedude327
    thedude327 Veteran Member
    778
    Feb 21, 2004
    Brighton,Michigan U.S.A.
    With 76cc heads, you'll definately need domed pistons to get 10:1 comp.
    and if your running nitrous, start thinking about forged rods, arp rod bolts ,
    forged crank too. It'll be cheaper to buy good parts to start with, unless you
    enjoy frequently disassembling and rebuilding your engine..............Oh and
    with domed pistons, make sure you check your valve to piston clearance or
    see the previous sentence............Good luck !!!!!!!!!!!!!!!! ;)
  3. pdq67
    pdq67 BANNED
    10,496
    Jul 26, 2001
    Columbia, MO, USA
    He said forged crank AND all Chevy V-8's have forged rods!
    As for 10 to 1 CR, a stock L-48 engine is 10.25 to 1 CR'd and more like 10 w/ 64 cc heads, -5 cc 4-notch flat-tops and .020" thick steel shim headgaskets!!
    I'd ditch your heads and find one's w/ right at 64 cc's or whatever your bore end's up making your CVR turn out to!
    Then use true flat-top forged pistons and go!! I say this b/c a small chamber and flat-top pistons create a much better eff. combustion vs domes where the flame front has to go around a big dome unless you really know what you are doing.
    Of course rebalance her too!
    And I would use good rod bolts too like Dude said.
    pdq67
  4. thedude327
    778
    Feb 21, 2004
    Whoops................Dropped the ball on that forged crank and should've said good quality forged rods like "I" beam or "H" beams. I would agree with the smaller combustion chambered heads too about 64cc with a good (forged)
    flat top piston would make more sense to me too. Je makes a good lightweight piston..............ask me how I know...................:bowtie:
  5. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    First off thank you guys for the quick replys.
    I realy don't want to "ditch" my $1400 AFR's.Can they be milled?
    What's the difference between a "true" flat top and a "false" f/t?
    Thanks again
    Sean
  6. thedude327
    778
    Feb 21, 2004
    AFR's website has a contact link to email them. They should be able to tell you how much, those heads of your's can be milled. Bear in mind that if you mill them, it may also require you to mill your intake manifold so that everything lines up when you bolt it together, otherwise you could end up with a vacuum leak where the intake bolts to the heads. I'll have to refer you to pdq for the difference in flattop pistons...................Good Luck!!!!!!!!
  7. Mwilson
    Mwilson Veteran Member
    18,561
    127
    Sep 14, 2004
    Raleigh / Holly Springs, NC
    Its gonna take a big dome I have .125 domes and 64cc with .037 quench and Im only 11.3X:1
  8. slamdik
    slamdik Member
    75
    Oct 18, 2004
    Ipswich Ma
    I found c/r calculator http://www.csgnetwork.com/compcalc.html.
    According to this I'll get about 9.8 w/ flat tops and 0 deck.
    May I'm screwing up some numbers.
    Let's say I can only get 9:1 w/ my 76cc . How much will this effect power vs.
    a 10:1?(is it worth worrying about it?)
    Sean
