350 vortec build.
Discussion in 'Engine Topic' started by bigblock665, Jun 6, 2011.
  1. bigblock665
    bigblock665 Veteran Member
    1,053
    Apr 7, 2009
    NY
    Iv got this 350 with flat top pistons. Its a cmj police engine I believe. Anyway, I can get a set of vortec heads for $22 per head and the vortec carb intake for just over $100. What cam should I use, and what can I expect to make for hp if I use and eddy 600 carb?
  2. bigblock665
    1,053
    Apr 7, 2009
    NY
    the heads are 906 casting.
  3. hhott71
    14,377
    9
    Mar 30, 2001
    Joplin Mo. 64801
    Heads been modified to handle a performance cam?
    If so you can get 400hp with the right combo easy.
  4. 81Dave
    81Dave Member
    44
    Apr 9, 2011
    Kerrville TX
    I ran a comp xe 274 in a 350 flat tops, vortec heads, in a 70 camaro a few years back.
    I had a vic junior and holley 750 but you should be close with your stuff anyway, ran 12.80s at 3200 pounds was a bunch of fun, idle was streetable but nasty sounding. Overall very cool and fun. Id reccomend it.
    Dave.
  5. bigblock665
    1,053
    Apr 7, 2009
    NY
    I found a full vortec engine that has the 906 heads that is supposed to make 350+ hp stock. Its got the roller cam and all. All I got to do is buy an intake and an electric fuel pump and regulator. I can get the engine for $175 with only 130,000 miles.
  6. bigblock665
    1,053
    Apr 7, 2009
    NY
  7. night rider
    night rider Veteran Member
    6,401
    Aug 6, 2002
    Bremen, Ga
    No stock vortec 350 made 350 HP. 255 HP IIRC was the stock power on the L31 5.7L 350 vortec truck engine
