355 not quite what I was expecting
Discussion in 'Engine Topic' started by Lewis82871, Jan 6, 2016.
  1. caribbean camaro
    caribbean camaro Veteran Member
    270
    Sep 1, 2002
    Antigua (via Florida)
    I went down your road with my first 355 build a long time ago -
    1) if its a heavy car - that big cam combo will feel like a dog you unless you crutch it with 4.11/4:56 gears or change the cam to a smaller cam
    2) unless you deck the block, stock builder pistons / stock style heads = low comp motor
    shoot for 11:5:1 and you will more than likely end up where you want to be - a strong hi-po motor
    In my experience - the old LT1 style knock off pistons (TRW L-2304) are the best starting point for a 355ci with an undecked block build on the cheap
  2. COPO
    18,944
    1,272
    Try it with timing set at 36* total or 16* initial.
