383 carb size?
Discussion in 'Troubleshooting & Diagnosis' started by S_ghost, Jun 10, 2021.
  1. S_ghost
    S_ghost New Member
    15
    Aug 3, 2017
    Some time ago I installed a blueprint 430hp 383 longblock crate engine in my camaro and have since done nothing but fight with issues of fuel in my oil with it. Now the blueprint website recommends using a 750 carb with it but my mechanic said that was too big and that's why I'm dealing with the fuel in my oil issue. When talking to the blueprint customer service rep he said the same thing, but I'm not sure if that's the case since that's what the website specs on the motor recommend or if they are just trying to screw me on my warranty. Should I have gone with a 600-650? Or should the 750 Holley I put on it have worked?
  2. camarochevy1970
    camarochevy1970 Veteran Member
    8,040
    182
    Jan 23, 2003
    Pittsburgh, PA
    a properly tuned 750 should have worked
  3. G72Zed
    G72Zed Veteran Member
    3,041
    1,516
    Sep 8, 2015
    What type of intake do you have, any spacers? A true 180* split dual plane takes a larger carb and is less "size" sensitive, and generally speaking, an open plenum intake setup is carb sensitive.
    A Holley 750 VS is one of the most versatile carbs sizes that you could use, they are not off on their recommendations.
    A Holley with a bad idle circuit, or other internal/tuning issues, regardless of cfm size can play havoc on the idle and transition circuits and run so rich it's washing the cylinders and adding to the dip stick level.
    MChamp likes this.
  4. COPO
    21,041
    2,581
    Either carb should work and should not be dumping fuel unless its not properly setup. I’d be cleaning the needle/seat
    and checking the float level. I’ve run both 750 and 780 on my 70 LT1 and both work well. But I would run what the manufacturer tells you, they built it.
    MChamp likes this.
  5. Coadster32
    2,297
    365
    Oct 2, 2013
    Milford,CT
    I have a 600cfm carb on my street driven 383 motor. All carbs in that general size range should work well. They will all need a bit of tuning to get it done though. If you already have a 750 carb, then work with that. You can increase/decrease the sizing as needed. My 600 carb needed to be sized up to accommodate, as expected.
  6. rocket dawg
    rocket dawg Veteran Member
    469
    59
    May 5, 2015
    Grand Rapids Mi
    Ran the 750 on a SBC400 ( 406) It ran strong. Eventually I put on a Sniper EFI unit and cant say enough good things about it so far.
  7. 67johnny
    67johnny Veteran Member
    318
    25
    Apr 14, 2016
    vancouver
    They ran 780 holleys vacuum secondarys on the 69 302 cubic inch motors with good success.
    Should be no problem on the 383.
    Find a good tuner !
  8. G72Zed
    3,041
    1,516
    Sep 8, 2015
    X2 ^^^ 67johnny nailed it right there, "Find a good tuner" that's proving to be more and more difficult as the years go by, hence the popularity of EFI swaps, not for power, but a lot easier to get someone to use a laptop then an "old guy" that knows his way around a Holley carb.
    Zstar likes this.
  9. COPO
    21,041
    2,581
    My head is my laptop on my Holley 4555. Head works well with no cooling fans.
    Zstar likes this.
  10. MChamp
    MChamp Veteran Member
    195
    51
    Jun 6, 2021
    north carolina
    what's your fuel pressure?
