383 cost from a machine shop vs crate engine.
Discussion in 'Engine Topic' started by ProjectCam76, Aug 18, 2015.
  1. ProjectCam76
    ProjectCam76 Veteran Member Lifetime Gold Member
    275
    Aug 10, 2015
    Birmingham, Alabama
    I appreciate all the responses! Some good info for me to think about.
  2. jasong
    jasong Veteran Member
    455
    Oct 24, 2009
    Las Vegas, NV
    I would say it depends on if you have the block already or not
  3. orkin
    orkin Veteran Member
    257
    Apr 27, 2011
    Texas
    if you are unhappy with the options for a crate motor, you could get a short block and use whatever top end you want.
  4. tom3
    tom3 Veteran Member
    12,943
    749
    Aug 1, 1999
    ohio
    Read the warranty very closely on those crate engines. Most will have a clause somewhere that the engine must be installed by a "licensed repair facility" or something similar. We put an ATK engine in my son's Jeep, cam chain tensioner was broke, hasd a used camshaft, cheap gaskets. Actually running fine at this point though. But read that warranty.
  5. tom3
    tom3 Veteran Member
    12,943
    749
    Aug 1, 1999
    ohio
    I'd like this deal, but sometimes a complete crate engine is about the same price as a shortblock due to volume sales.
  6. hutchenc
    hutchenc Veteran Member
    345
    Aug 21, 2007
    Wyoming/Colorado
    Probably quite a few options. I'd say whatever you do, but a short block that's either set up for a roller cam or already has one.
    Also, I'd contact Mike Lewis at http://www.lewisracingengines.com Mike builds awesome motors and will spec it just for your car. I had him build a 420 SBC (based on a Dart SHP block) for me and even with shipping, it was about the same price as a crate 427 SBC would have been, but with Mike I got the cam, compression, heads, and intake I wanted...the components were better than a comparably priced crate motor too boot!
    This was not a cheap motor, but he has very competitive prices.
  7. sooner
    sooner Veteran Member Lifetime Gold Member
    1,414
    Mar 11, 2009
    Perry,Ok
  8. Marv D
    10,851
    May 12, 1999
    Devils own training ground,,, aka Arizona
    And don't that alone just make you wonder......
    Buying in bulk is only going to save you so much over buying a few at a time like your local machine shop,, Jobbers don't get any 'great' break in price. So where are they cutting corners / costs?????
    It can be an ordeal finding a local automotive machine shop that is reputable and does quality work. But once you do,,, do everything you can to help the guy stay in business. They are worth your loyalty. It's pretty tough to keep a couple million dollars in quality machines and competent machinist around when your competing with these low-buck mas-produced crate motors full of un-named parts and pieces (not slamming anyone crate,, just saying lots of corners have to be cut somewhere to sell these things for 'cost' of quality parts to build the same motor)
    In the end guys,, all you can do is hope you get what you pay for.
  9. Philly
    Philly Veteran Member
    1,657
    Mar 11, 2009
    404
    By the time its all together, Carb, intake, wires, plugs, headers, water pump, distributer, fan, pulleys, balancer.. etc etc..its easily $5000 if not more. I built my BBC for about the same all myself with a reputable machinist and thier costs included..Quality parts and cast 781 heads which i had redone as well. I dont understand why the sell them like that, no matter what, theres only so much you can do with that cam, compression ratio, and heads anyways. Why not just finish the motor and sell it as its supposed to be...leave the guesswork out of it and list all the parts... I never understood that. I find it financially misleading.
  10. 77 cruiser
    77 cruiser Veteran Member
    564
    30
    Nov 17, 2006
    Frostbite Falls MN
    Did you meet him?
    Class act that Wolfie!
