Maybe I'm totally reading this wrong on how you did it, but I looks like you rotated your crank to the 12* mark on the balancer and plopped the distributor in.
If so, you are way off the mark on timing. The balance must be at 0 which is top dead center for number 1 cyl. THEN you install the distributor, and get the car fired up.
The 12 degrees of timing advance comes from turning the body of the distributor while shining a timing light on the balancer mark/timing pointer.
