3pc spoiler studs
Discussion in 'Body Restoration' started by CaliCamaro75, Oct 11, 2017.
  1. CaliCamaro75
    CaliCamaro75 Veteran Member
    495
    38
    Sep 6, 2015
    Winchester,CA
    Where can I get some replacement studs for my 3pc spoiler?
    An where to purchase the hardware kit also?
    I have a 75 it's going to mount too. I got new quarter's and repaired trunk lid. So new holes have to be drilled.
  2. CamarosRus
    CamarosRus Veteran Member
    8,546
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    I can tell you that using centering screws 1/4x20 from McMaster Carr is fastest least expensive
    most fool proof method for locating new holes
    Search elsewhere on this site for Scott Kiehn's advice to myself
  3. CaliCamaro75
    495
    38
    Sep 6, 2015
    Winchester,CA
    I remember reading that. Thank you for the reminder.
  4. 71 rs BBC
    71 rs BBC Veteran Member
    477
    65
    Nov 28, 2016
    Indy
    Home Depot, Lowe’s whatever and pick up some 1/4-20 set screws. They even have stainless. Grind a point on the end for marking. After you can unscrew them and turn them around so there’s not a point sticking down from the deck lid. M2c. Good luck
  5. CamarosRus
    8,546
    148
    Feb 16, 2000
    71 rs BBC......The McMaster Carr 1/4x20 centering screws (set of 7) come with install tool
    for under $20.....are all perfectly the same
    You suggest to buy hardware store pcs, grind yada yada to save $20....Please !!!!!!!!!
  6. 71 rs BBC
    477
    65
    Nov 28, 2016
    Indy
    Easy killer! Lol!!! Some of us like to work with our hands. Sometimes it’s nice to have options. Yes I have a lathe if it needs to be perfect. I also have the 5” thick McMaster catalog. Yada Yada Yada it’s not always about the money. Lol!
    brooksman9 likes this.
