4" Cowl, enough clearance for a single plane with a Big Block?
natzx7
135
St Petersburg FL
Does anyone have experience with this? I'll be swapping motors in a few months, and my 427 BB with a dual plane just fits under a steel 2" cowl hood. My next motor is going to be a Big bore BBC standard deck, but with a single plane Edelbrock (I think a Super Victor) and a 4500 series carb. I'd like to run a conventional air cleaner like a standard Moroso. I really don't want a 6" cowl if I can help it, but may need another inch or so for a nitrous plate. Hoping someone who has dealt with this might have some advice. Thanks !
NTSTLKR
53
NH Seacoast
I think you'll be OK if you use a drop base air cleaner. You'll be able to just close the hood.
I have a Victor under a 4" Cowl.
But I also have a Nitrous Plate under my Dominator- and couldn't use the Moroso drop base lid- so I designed & 3D Printed a custom one to fit.
natzx7
135
St Petersburg FL
Wow thanks, that's really helpful. Judging by the foil it's pretty close with the plate and the custom lid!
1980RS
6,946
MN
I have an 80 Camaro with a 4" cowl hood and it clears my BBC with the old Weiand Team G intake that's pretty tall. The truck is to use a good drop base air cleaner on the street with the hood.
natzx7
135
St Petersburg FL
Thanks for the replies everyone. I'd hate to drive a 6" cowl on the street, I don't really think it's doable. These pics are of my buddies Chevelle, this a Moroso drop base air cleaner, but I don't think they make a drop base like that for a Dominator.
NTSTLKR
53
NH Seacoast
I had a much taller Harwood Aero on mine previously- and it was tough to see around to the RF.
The 4" cowl is way better for visibility- and it's legal (here in NH)
Mine is a Moroso drop base for a Dominator: https://www.moroso.com/16-low-profile-air-cleaner-with-dropped-bottom65920/
Problem is at the very front where the cowl starts to drop down- that's where there's not a lot of room.
Also need to watch the passenger side- because the BBC is not centered in the engine bay.
I believe I also had to use a 3" element- and as such there was not much clearance between the lower and upper parts of the assembly.
The Filter Lid I made used a different curvature to maximize the clearance in that area.
You could also use one of those flat K&N lids with the filter built into it- in a pinch.
natzx7
135
St Petersburg FL
Thanks, I"ll order that Moroso 65920. Looks like they're out of stock but I won't need it until the fall or so. Super helpful info and pics! I forget about restrictions like hood scoop size up in the north east. I grew up in RI and the cops would literally be waiting for me to back out of my driveway with glasspacks on my '70 so they could give me a ticket and send me back to inspection. Down here in Florida, it's pretty much anything goes, slicks, 36" lift kits, open headers LOL ( but I still don't want to try to navigate a parking lot with a 6" cowl) Thanks again. - Nat
