4" dash speakers; PICS
Discussion in 'Car Audio, Electronics & Security' started by Shields, Mar 21, 2015.
  1. Shields
    Shields Veteran Member
    117
    Nov 19, 2013
    kelowna, british columbia
    I had my gauge cluster out to clean up the wiring and convinced myself to remove the 4x10 that was hanging on by the last 3 threads in the bracket, not a single spec of the paper cone remained after 30+ years of sun damage, it was seriously destroyed, I decided to make the bracket to house 2 4" speakers instead. The original speaker bracket ended up being to shallow and I knew the tweeters would hit the dash, so I built a completely new bracket from 3/4 mdf, the 3/4 mdf was overkill but I had it lying around the garage, here are the pics
    Getting the spacing between the bracket and the speaker frame so that the frame would sit tight against the dash took some math but it worked out pretty well
    I was a little skeptic as to how long these speakers would last in the sun so I stole some of my moms pantyhose (LOL) and stretched it over the frame, thanks a board member for the idea lol, probably could have painted the frame black but you cant see it anyways
    it bolted right up, I put 3 layers of 1/8 adhesive foam around the edges to kill the rattling, I had a fight to squish the speakers to the dash while I fumbled with the screw, but it doesn't move at all, no squeaks and no rattles.
    I wont get any separation from these kenwoods but I'm super happy I'll actually have some music coming from the dash rather than dust from the old 4x10, lemme know whatcha think!
  2. saved1992
    saved1992 Veteran Member
    129
    Mar 21, 2013
    bennington, ne
    Looks great.
  3. MartyO
    MartyO Veteran Member
    290
    Sep 7, 2014
    Hiram, GA
    They look very good!
  4. greaser
    greaser Veteran Member
    720
    Sep 22, 2012
    Beaumont, Texas
    Nice job. I used an original speaker and cut out enough for two speakers to mount. Plus still had original foam spacer so didn't have any spacing issues. Picked up some dark gray thin fabric from hobby lobby.
  5. AJ_72
    AJ_72 Veteran Member
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    Uhhhh . . . used panty hose. That's different.
    Better than used whitey tighties, I guess. :screwup:
  6. Shields
    117
    Nov 19, 2013
    Hahaha they were brand new, had a $22 tag on them so hopefully she doesn't wring me neck
  7. AJ_72
    5,129
    Jul 3, 2003
    Chebanse, IL USA
    Yeah. I'd be careful. What's left of them could serve as a noose. LOL
  8. loyal guardian
    loyal guardian Veteran Member
    697
    Aug 28, 2013
    helena mt
    if ya still got extra MDF maybe consider trying to make a speaker box around them? they look great and it looks like you have room to fit a small box around them. do research before making the box, but its an idea
  9. Shields
    117
    Nov 19, 2013
    I thought about ordering the GM cardboard enclosures and retrofitting them to fit the speakers, so I could isolate them from the underworld that exists under all of our dash pads, I'll keep the thread posted if I do decide to go with enclosures.
    While we're on the subject of enclosures, you wouldn't happen to know if it's alright to leave my 6x9s without enclosures in the trunks with two subs would you?
  10. loyal guardian
    697
    Aug 28, 2013
    helena mt
    that i would not know. i know about the box because i redid my trunk shelf with MDF and plan to install boxes on them. i dont know if itll help but its what i will do
