4" stroke 4.130 bore vs 3.9" stroke 4.175 bore
Discussion in 'Engine Topic' started by phantom69, Mar 8, 2021.
which setup be best for a mostly street application
Poll closed Apr 7, 2021.
  1. 4.130 bore 4" stroke
    1 vote(s)
    20.0%
  2. 4.175 bore 3.9" stroke
    4 vote(s)
    80.0%
  1. phantom69
    phantom69 Member
    38
    Dec 16, 2020
    all things being equal which of these combos be the best for longevity and ease on the motor in a mostly street driven setup
    cam 227int./238exh @.50 lift 116.5 LSA if you wanna get technical
  2. G72Zed
    G72Zed Veteran Member
    3,131
    1,583
    Sep 8, 2015
    If the bores are stable and ring seal is not compromised, I like the 3.900 stroke with the 4.175 (427.13 ci) bore in most all cases. Even better the 3.5 or 3.625 crank in a large bore.
    If your pushing the bore thickness limits with the 4.175, and looking for tire melting (ave.) TQ in the lower rpm's, the 4.00 x 4.130 (428.7) is ahead, as long as the pin is not in the oil band.
    Looking at the cam, is this an LS build??
  3. phantom69
    phantom69 Member
    38
    Dec 16, 2020
    you could say that it is an LS build yes and no..its gonna be a certified freakshow if i can pull it off!
  4. G72Zed
    3,131
    1,583
    Sep 8, 2015
    Is it a Dart Gen 1 block for the LS head type build ?
  5. phantom69
    phantom69 Member
    38
    Dec 16, 2020
    its a manhattan project i cant give out such details its not that tho
  6. Lowend
    16,494
    1,275
    Mar 25, 1999
    San Jose, CA, USA
    The short answer: assuming you are staying within good machining tolerance, the larger bore is almost always better.
    Larger bore's unshroud valves and increase displacement without increasing piston speed.
