454 build. What hood do you have to run a big block?
Discussion in 'Engine Topic' started by QUAKE_WARS, Dec 8, 2020.
  1. QUAKE_WARS
    QUAKE_WARS Veteran Member
    2,313
    315
    Dec 19, 2008
    Can a 2 or 2 1/2 inch cowl be used with either of these intakes? I dont need a 4 inch cowl hood. Trying to keep the clean looks with a NOT SO TALL hood.
    What ya got and what hood do you use with a big block?? Trying not
    to go LS swap, but will if I cant find a solution. Thanks
  2. carhead22000
    carhead22000 oldblue
    835
    378
    Sep 5, 2011
    canada
    i run a airap with drop down air cleaner.but had to mod my hood on inside a bit.81z28.and stock hood.i,d say you be fine.
    QUAKE_WARS likes this.
  3. CorkyE
    11,513
    967
    I ran that same combo, but with a small block. I don't think you can stuff a bbc with an air-gap under a stock hood.
  4. Zspoiler
    Zspoiler Veteran Member
    4,159
    501
    May 6, 2012
    Federal Way, Washington
    Try a 2' cowl hood or a drop based air cleaner from 1970 1/2-3 Camaro.
  5. Twisted_Metal
    30,349
    2,985
    The 2nd gen SS BBC Camaros used a flat hood.
    The Weiand Stealth is just a little bit taller in front than the RPM Air Gap but shorter in the rear.
    The Weiand Action Plus is shortest in front and splits the difference in the rear.
    Stealth...………. Front 4.75" - Rear 5.75"
    Action Plus..... Front 4.25" - Rear 5.87
    Air Gap...…….. Front 4.45" - Rear 6.0"
    It seems to be the front of the air cleaner where there is the least amount of clearance on our cars so a Weiand Action Plus would probably fit with less fitment problems.
    If you really want a cowl hood... you won't need much height on the cowl with any of them unless you plan on using a big carb spacer.
    carhead22000 and QUAKE_WARS like this.
  6. QUAKE_WARS
    2,313
    315
    Dec 19, 2008
    thanks everyone. Should I use the stands 70/71 maybe up to 72. or clam shells? (motor mounts)
  7. BigBlock73
    2,187
    107
    Jul 10, 2002
    Accord,New York
  8. 73RATTYZ28
    73RATTYZ28 Veteran Member
    580
    47
    Feb 23, 2001
    White Plains NY USA
    Good question on the clamshell mounts. I could only fit the gm factory rectangular low rise aluminum intake off the ls6 chevelles and an edge rock torker 2 on my 73. Neither are great intakes so I went to a steel 2” good mark cowl hood.
  9. QUAKE_WARS
    2,313
    315
    Dec 19, 2008
    Do you have pic's?? Thanks.
  10. QUAKE_WARS
    2,313
    315
    Dec 19, 2008
    thanks everyone.
    Ok, Let me try this differently. I only want to use one of those 2 intakes. will it work with a 2 or 2 1/2 inch cowl hood? I do not want to
    use the stock hood. I do not want to use a race car hood either lol. I know I need a drop base air cleaner. Lots of big block cars on this forum, someone has to have this setup.. I would think it would be so common on F-BODIES. As far a motor mounts, clamshell or stands to drop engine lower?
