454 Carb
Discussion in 'Engine Topic' started by badazz70z28, May 29, 2012.
  1. badazz70z28
    badazz70z28 Veteran Member
    873
    Sep 12, 2004
    mechanicfalls maine usa
    definately new to big blocks but i just traded the vega for a 89 rs camaro w 454. i will assume it is stock so keep that in mind, what would be a good carb for this? it has an edlebrock 600 on it which to me seems too small for a 454
  2. cars4life
    cars4life Veteran Member
    645
    Jan 11, 2010
    Poughkeepsie N.Y.
    You can go on holleys web site and look at there Carb calculator. I think a 780 cfm or more would be better.
  3. Air_Adam
    Air_Adam Veteran Member
    2,927
    Feb 7, 2004
    Saskatoon, SK, Canada
    Holley 3310 would be a good choice for a stock all the way to fairly hot 454.
  4. 5spd540
    12,382
    17
    Sep 19, 2009
    Guyton, GA
    No you need the carb you sold me:rolleyes:
  5. BondoSpecial
    8,694
    Sep 20, 2004
    Connecticut
    If you like Edelbrocks, a 750 electric choke would be nice on that, I have run that carb on Pontiac 400, Ford 429, and Ford 460, all auto's, with good results.
  6. my24ktrat
    my24ktrat Veteran Member
    1,227
    Jul 5, 2007
    Roch., NY
    ...Try an edelbrock quadrajet , put one on a friends stock 73 454 el camino , runs perfect, DC:bowtie:
  7. Damon
    Damon Veteran Member
    12,939
    23
    Nov 16, 2000
    Philly area
    You know what I'm going to say. And you know that I'm biased. But being biased doesn't mean that I'm not right.
  8. SavingTheBird76
    SavingTheBird76 Veteran Member
    313
    Dec 13, 2009
    Mentor,Ohio
    Holley is so much easier to tune,cheaper and simple as heck.
    The 3310 would be a great place to start,and under $300.
    They run great right out of the box.
  9. hhott71
    14,377
    8
    Mar 30, 2001
    Joplin Mo. 64801
    Q-Jet is always the perfect size. Flows up to 750 CFM which is 5800 RPM @ 100% pumping efficiency,, or over 6000 in real life before 1.5" vacuum is registered at WOT.
  10. krabben1
    8,244
    72
    May 16, 2007
    ( . Y . )Delco
    Holley specs called for a hair smaller carb than I got.I have the 770 ultra avenger and Im only putting out 425 horse.But mine likes it.
