454 w/th350???in my 79??
Discussion in 'High Performance Modifications' started by camaro19791000, Nov 29, 2010.
  1. camaro19791000
    camaro19791000 Veteran Member
    103
    Feb 28, 2009
    El paso Texas
    Will a 454 bbc work with a th350 and will it fit in under stock hood????
  2. BB1969
    BB1969 Veteran Member
    270
    Sep 1, 2010
    HILO HAWAII
    A low deck 454 with a stock intake will clear. If you run a higher intake with a drop base it will be close. You should cosider a cowl hood then you can run a good intake and cleaner with no problems.
  3. mrdragster1970
    7,821
    507
    Apr 12, 2007
    There are a zillion 350's behind BBC's.
  4. z28rod
    z28rod Veteran Member
    4,472
    Apr 30, 2009
    hopewell junction,ny
    Yes Th350 Are Great Trannys It Will Be Fine, Just Put A Dual Plane Intake Like A Performer And Should Fit, High Rise Intake Then Might Be Clearance Problems.
  5. onebad71
    onebad71 Veteran Member
    412
    May 15, 2010
    georgia
    agree with the above it should fit depending on intake,air cleaner
  6. Greg Mc
    Greg Mc Veteran Member
    1,243
    10
    Mar 18, 1999
    Hernando, MS
    Just put a bb in my 81z with a performer rpm intake and a holley 750 carb and it will NOT clear.....on my car. I am using an Edelbrock 14" drop base air cleaner. I cut out the opening in the hood but had to remove 2 of the mounting tabs for the stock air induction scoop. Still having some contact issues, the front of the air cleaner is now hitting a cross reinforcement brace on the underside of the scoop. May just get a smaller air cleaner and solve the problem.
    And I am using my TH350 behind the BB.
  7. 496z28
    496z28 Veteran Member Lifetime Gold Member
    967
    8
    Sep 23, 2007
    Oklahoma City
    There are hundreds of threads on this setup and swap! Im running a th350 behind my 496 in a 79z.
  8. scot1074
    scot1074 Veteran Member
    360
    Jun 3, 2004
    Prospect Ct, USA
    No sorry won't fit under a stock hood sorry! I'm close with a drop aiir cleaner and a 2 inch element with a 3 inch cowl! And yes my motor mounts are right!
  9. z28rod
    4,472
    Apr 30, 2009
    It Will Fit But You Need To Use A Low Intake, Like A corvette Style alum Intake, The 80 And 81 Are The Worste Ones Cause Of The Way The Air Induction Is Set Up And The Hood Reinforcement Is Designed.
  10. Mike-78 Z-28
    Mike-78 Z-28 Veteran Member
    1,909
    Mar 4, 2003
    ElDorado Arkansas
    An Edelbrock Torker 2-2,0 will clear the stock hood but will be down on power compared to a big dual plane but that really doesn't matter if you can't cruise.
