4L60e-big round plug-trans.fluid
Discussion in 'Transmission & Driveline Topics' started by SpeedAddict02, Sep 4, 2013.
  1. SpeedAddict02
    SpeedAddict02 Veteran Member Lifetime Gold Member
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    The big round plug at the rear of the trans, on top of the pan.. normal for it to have fluid coming out, inside the plugs? I originally thought it was water from pressure washing the motor/trans, put a rag in to pick up the water and it was red trans fluid in the plug housing..
  2. retorq
    retorq Veteran Member
    4,921
    May 13, 2003
    Kingman, AZ
    No, that is the electronics connector, there is a cork gasket that goes there like on the distributor.
  3. SpeedAddict02
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    Great..lol does the pan have to come off to pull the connector?
  4. SpeedAddict02
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    any idea where I can find it? tried the local parts places and bulkpart.com with no luck.. still searching.
  5. retorq
    4,921
    May 13, 2003
    Kingman, AZ
    Yeah I'm pretty sure it does have to come down.
    You will probably have to get it from a transmission place specifically ...
  6. SpeedAddict02
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    Thanks. From what i have found it's held in by clips. You push it up from the bottom till they all catch on top. Has an o-ring in the center, kinda like the piece that the speedo cable screws onto on a th350. But i can't see the o-ring causing fluid in the connector. Have a feeling i might be changing that whole connector& harness bc i cant find them separately unless i can find one in the junkyard.
  7. retorq
    4,921
    May 13, 2003
    Kingman, AZ
    Yeah it's held in by clips, maybe there is a crack in there somewhere and the fluid is seeping up thru ...
  8. SpeedAddict02
    4,539
    Dec 31, 2002
    Wallkill, N.Y.
    That's what I figure. No big deal. Just another thing to add to the list. Lol
