4l60E Floor Shifter
Discussion in 'High Tech Retrofits' started by Dcmusch, Jun 19, 2015.
  1. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    Ive seen a bunch of different posts about having problems with floor shifters. What shifters are you using on your cars with a 4l60E? Can you post pics?
    Thanks
  2. rs454
    rs454 Veteran Member
    723
    Feb 15, 2001
    kutztown pa usa
    i used the stock horseshoe shifter in my 71..used the shiftworks conversion..easy to do ...
  3. hogg
    hogg Veteran Member
    3,174
    29
    Dec 29, 2000
    pegram,tn.,cheatam
    I use the stock shifter ,, filled a little on the inside shiffter plate
  4. hot72rod
    3,019
    39
    Aug 9, 2000
    Phenix City Al / Columbus Ga
    I keep thinking I'm going try to use the 5th gen console and shifter. I might also try to convert to a hand brake.
  5. 1st and goal
    1st and goal Veteran Member
    400
    Nov 5, 2005
    Seacoast, NH
  6. sbca96
    sbca96 Veteran Member
    2,897
    Oct 25, 2004
    Santa Barbara, Ca
  7. Dcmusch
    Dcmusch New Member
    27
    Aug 21, 2014
    San Antonio, tx
    Im looking for a shifter that I dont need a console for.
  8. cvhu
    cvhu Member
    97
    Jan 18, 2012
    sarnia, ontario, canada
    i used a 4th gen 4 speed automatic shifter with my stock 78 console
