Where did you pick up the shaft from and what did it run you.
May 19, 2015 #401 hot72rod Veteran Member Aug 9, 2000 3,025 Phenix City Al / Columbus Ga Where did you pick up the shaft from and what did it run you.
May 19, 2015 #402 Mike Busutil Veteran Member Oct 16, 2010 629 Yuma Arizona I got mine from Amazon for $129.00 http://www.amazon.com/Parts-Place-I...et:camaro&keywords=1981+Camaro+steering+shaft You can find one at Classic Industries for $159.99 http://www.classicindustries.com/product/1981/firebird/parts/15028.html Or this one from Camaro Central for $139.95 http://www.camarocentral.com/1978_1981_Camaro_Steering_Column_Shaft_p/ste-177.htm
May 19, 2015 #403 Mike Busutil Veteran Member Oct 16, 2010 629 Yuma Arizona Mine is already in the car, it fit with no issues.
May 28, 2015 #404 Mike Busutil Veteran Member Oct 16, 2010 629 Yuma Arizona I just had a thought... Since I upgraded all four wheels to big disk brakes, what keeps my wheels from locking up when I step on the brakes?
May 28, 2015 #405 hot72rod Veteran Member Aug 9, 2000 3,025 Phenix City Al / Columbus Ga That's the thing, you don't want your brakes to lock up.
May 28, 2015 #406 Mike Busutil Veteran Member Oct 16, 2010 629 Yuma Arizona Exactly my point. I dont want to get on the road and start braking then go sliding. I guess I'm asking if the brake booster, master cylinder and proportioning valve is all I need or am I missing something else? Last edited: Jun 3, 2015
May 28, 2015 #407 hot72rod Veteran Member Aug 9, 2000 3,025 Phenix City Al / Columbus Ga That's all you should need. But don't think just because you have bigger brakes that you can't lock them up. I have locked up brakes on a newer car with ABS. So it's not impossible to do, just harder.
May 28, 2015 #408 Mike Busutil Veteran Member Oct 16, 2010 629 Yuma Arizona Thanks. I was thinking the larger disks brakes would be easier to lock up which got me thinking if I were missing anything or if my setup would be ok. Thanks again. Last edited: May 28, 2015
May 28, 2015 #409 hot72rod Veteran Member Aug 9, 2000 3,025 Phenix City Al / Columbus Ga The larger brakes will be harder to look up.
May 29, 2015 #410 G global warmer Veteran Member Apr 1, 2010 494 Saratoga Springs NY where did you get the LED tail lights??
