5gen 2012 Camaro center console in my 1970
Discussion in 'Interior Restoration' started by Tpichevy, Feb 25, 2017.
  1. grzewnicki
    3,463
    187
    Dec 9, 2009
    Gordon from Jacksonville Fl
    I found them on line for $28 through GM. I got my console with one broken attach point on right hand side cover. Was gonna order a new side (seller refunded me $25), then thought, I'm just gonna epoxy it together, not like I am ever going to take the side off, heck our original consoles are one piece...right? Hopefully start trial fit here in the next few days. It looks like my shifter will come up where the tray is vs the shifter hole so I may have to modify. Would like to use parking brake handle hole for cell phone, I may try to fabricate something so when you place the phone into the slot it plugs into a charging point, sort of like a docking station.
  2. CAMeeks
    CAMeeks Veteran Member
    699
    42
    Jan 5, 2014
    Deer Park, TX
    I have the LS3 / T56 Magnum. How are y'all using the stock shifter knob and what shift stick works best?
  3. typeLT73
    typeLT73 Member
    94
    May 13, 2013
    New Mexico
    Does anyone know if it's worth buy the gauges? Can they be used on a second?
  4. CAMeeks
    699
    42
    Jan 5, 2014
    Deer Park, TX
    The gauges are controlled by the computer. I looked all over the internet and decided not to try it.
  5. czizza
    czizza Veteran Member
    1,073
    85
    Jan 8, 2004
    N. Massapequa, NY, USA
    What are you guys doing about the emergency brake?
  6. CAMeeks
    699
    42
    Jan 5, 2014
    Deer Park, TX
    I want to attempt to use it.
  7. CaliCamaro75
    CaliCamaro75 Veteran Member
    441
    31
    Sep 6, 2015
    Winchester,CA
    I was gonna try to use it also. Not to that point yet. CAMeeks keep us updated. Really interested in switching it up.
  8. Tpichevy
    Tpichevy Veteran Member
    508
    16
    Jun 21, 2016
    Boise id
    If you are using a lst56 then the 2010+ stock shifter knob should work. For my t5 shifter and knob I used a big grommet that slides over the shifter stick then the boot over that so the grommet holds the boot up vs falling down.
  9. typeLT73
    typeLT73 Member
    94
    May 13, 2013
    New Mexico
    Can anyone send me some overall dimensions? I would like to compare it with the original console from my 73.
    Greatly appreciated.
  10. cadmanmeg
    cadmanmeg Veteran Member
    1,754
    Mar 20, 2006
    Bothell, WA
    Sweet, I am going to do this with my 70!
