5gen 2012 Camaro center console in my 1970
Discussion in 'Interior Restoration' started by Tpichevy, Feb 25, 2017.
  1. SS Performance
    SS Performance Veteran Member
    227
    35
    Nov 17, 2016
    Has anyone found any additional information on this shifter?
    I'm going with a 4L80E and would like to go with the horseshoe shifter.
    Thanks
    Craig
  2. CAMeeks
    CAMeeks Veteran Member
    699
    42
    Jan 5, 2014
    Deer Park, TX
  3. SS Performance
    227
    35
    Nov 17, 2016
  4. Da-bigguy
    4,681
    720
    Jan 19, 2010
    Cypress, TX
    I bought an adapter kit to enable the original horseshoe shifter to work with the 4L80e that I'm installing along with an LS7. Here is a link to the kits they have for early 2nd gen Camaros. They have the ones for the 4L60, 4L80 and 6L80 towards the bottom of the page.
    http://www.shiftworks.com/camaro-68-72.htm
  5. Itsadryheat79
    Itsadryheat79 Veteran Member Lifetime Gold Member
    314
    Aug 4, 2009
    Chandler, Arizona
    I have that kit for my 4L85E LS7 in a 79z28 - kit works great with the standard 79z shifter. - I love the stock look
  6. SS Performance
    227
    35
    Nov 17, 2016
    I went old school looking for a 5th gen console. I called the local junk yard. They didn't have one but they told me where one was not too far away. Drove up there picked it up (they pulled it for me) $65 out the door. And I got to inspect it first! Can't do that on ebay!
    AlbertaZ28 likes this.
  7. 8pack
    2,655
    155
    Aug 29, 2007
    Western, MA
    I had another post where I was thinking about fiberglassing a used stock console I had. It is in my build post...but xten found me one for $100 only missing the shifter boot. Click on my build thread and go to page 36 to see pics of it in my car....looks sweet!
  8. Green hornet
    Green hornet Veteran Member
    1,844
    375
    Oct 11, 2015
    North Bay, CA
    What transmission do you have? I picked up a 5th gen console a while ago and don't think I can make it work. I have a Muncie 4speed in my car and the shifter is offset to the left of center.
    Has anyone tried this console with a Muncie 4speed ?
  9. 8pack
    2,655
    155
    Aug 29, 2007
    Western, MA
    I have a TKO 600 with the Hurst Lighting shifter. It fit almost exactly in the stock location, off by maybe an inch. To get the console in to slide it over the shifter with it parallel to the dash, then drop it down and rotate into place, there is quite a bit of room for adjustment. Take the front plate off and put it on after it is in place.
  10. Green hornet
    1,844
    375
    Oct 11, 2015
    North Bay, CA
    Ok I dug my console out and set it in place. Here are two photos of the console with the shifter in reverse. Give me your opinion. I'm unclear about what to do about the shifter boot at this time but that's a minor detail. I do like how it looks and it is easy to put in and take out.
