6.0 Lq4 Comp ratio
Discussion in 'Engine Topic' started by Justin Berke, Nov 15, 2019.
  1. Justin Berke
    Justin Berke New Member
    29
    Jan 11, 2019
    British Columbia
    So I'm trying to decide what pistons and rods I should go with to keep the stock comp ratio with the 317 heads. Here's what I found: BLS1111-030-8 pistons and 6125O3DL19 rods. Would this keep the stock compression ratio? If not what pistons would be best with the .6125 rods? Thanks
  2. John Wright
    15,230
    411
    Aug 9, 2002
    Rustburg, Va
    I thought the stock rod was 6.098"
    Wait, you swapped to the 6.125 to get closer to zero deck.
  3. 1980RS
    1980RS Veteran Member
    5,500
    1,808
    Jun 17, 2006
    MN
    If I were to build a 6.0 my first choice for heads would be a set of ported 5.3's, smaller ports, higher velocity means more power plus higher compression.
  4. Justin Berke
    29
    Jan 11, 2019
    British Columbia
    Yes the stock rod is 6.098, oh and I forgot to mention, the build is going to be for boost, pt88 turbo most likely
    John Wright likes this.
  5. SRGN
    SRGN Veteran Member
    681
    241
    Feb 20, 2009
    Central NJ
    If anything, I'd run a shorter rod to keep the pin further from the crown on a boosted build. I'd also look into a slightly dished piston, the combo you posted is more ideal for a Max effort NA build. The compression with 5.3 heads and those pistons would be a little higher than I prefer for a boosted application, but to each their own.
