7" 3rd gen tire size option
Discussion in 'Suspension, Steering, Brake & Wheel Topics' started by Milligsc, Jul 18, 2015.
  1. Milligsc
    Milligsc Member
    71
    Oct 4, 2012
    Janesville, wi
    Hi Guys, I have a set of stock 85 5 spoke camaro wheels I'm putting on my 79Z. I looked in the tire sticky but still not sure here. What is the largest tire I can put in back? What would you guys recommend. I;m thinking 255 60 15 in back and 215 65 15 in front. Any info appreciated. I do have 1" lowering coils in front, the rest is stock.
  2. whitess
    whitess Member
    88
    Dec 21, 2008
    Frederick, CO
    Don't know about the rears but with those wheels the stock size was 215/65R15. T/A (15"), Monte Carlo SS, GN and 442's were the same too.
  3. 3SLO5
    3SLO5 Veteran Member Lifetime Gold Member
    3,639
    Jan 7, 2001
    Edison NJ USA
    255 60 in rear. 225 60 in front slammed 235 if not that low 245 will work at stock height.
  4. tom3
    tom3 Veteran Member
    13,926
    1,452
    Aug 1, 1999
    ohio
    Be sure and check the inside bead sealing surface on those old wheels. Get crusty corrosion build up, make for leaking tires.
  5. The Champ
    The Champ Veteran Member
    5,552
    1,165
    Sep 14, 2000
    MN
    With a 1" drop in front, I'd go with 235/60/15's up front. Same height as the 215/65/15's (which were NOT the stock tire for a '79Z - 225/70/15's were).
    With lowering the front, you won't be able to put the stock tire size (26.85") up front. The 235/60/15 is 26.1".
    In the back on a 7" rim the 255/60/15 is the best bet - 27.1" tall - so it fills the rear wheel well nicely.
  6. whitess
    whitess Member
    88
    Dec 21, 2008
    Frederick, CO
    In 82 - 92 they WERE 215/65R15's. :)
  7. The Champ
    5,552
    1,165
    Sep 14, 2000
    MN
    The car in question is a 79Z...:bowtie:
  8. typeLT73
    typeLT73 Member
    94
    May 13, 2013
    New Mexico
    https://www.tacomaworld.com/tirecalc?tires=235-60r15-245-40r18
    This is one kool tire size comparison that I use often. It is very useful when comparing original size vs. what ever you are thinking of using.
    I am currently running 245 45 R18 and need some new tires and was thinking of running 245 40 R18. not sure if would be too low.
  9. Z-WIZZ
    Z-WIZZ Veteran Member
    1,297
    Mar 18, 2004
    FLA
    think BS was different on those later wheels
  10. 3SLO5
    3,639
    Jan 7, 2001
    Edison NJ USA
    15x7 82-92 f body wheels are the same 4.25 backspace as 2nd gen 15x7 wheels.
