70’ 12 Bolt Rear End
Discussion in 'VIN, Trim Tag & Drivetrain Decoding' started by Chevy911, Apr 9, 2021.
  1. Chevy911
    Chevy911 Member
    30
    Feb 9, 2021
    South Florida
    Ok guys, if you’ve been following my post I’m trying to give my car the best of the best stuff.
    I found a guy who has a 12 Bolt out of a 70 camaro that he said he brought 30yrs ago at a swap meet. I need help identifying this rear end to determine it it is in fact a REAL 70’ F-body rearend.
    Here are the numbers off of it:
    Front Passenger side: COS 0316G4
    Top rear Driver side: B120
    Bottom front Driver side: 3969341NF
    Top rear Passenger side: C0N2
  2. Gary S
    23,925
    1,513
    COS is the correct code for a 1970 Camaro 12 bolt with 3.07 gears and no posi. It likely came out of a SS350 with automatic tranny. But, who knows what is inside it today. The gears could easily have been changed and a posi installed.
    The 3968341 casting also identifies it as a 1970 F body diff.
  3. Chevy911
    Chevy911 Member
    30
    Feb 9, 2021
    South Florida
    What is it worth?
  4. badazz81z28
    20,716
    1,415
    Alabama
    Good question....what is it worth? That's question only you can answer lol. Consider if its still a open 3.07, you will need to put $1000 into it to make it a posi with good gears. A "best of the best" option to me is not to invest in a stock 12 bolt that is not correct for your car. I would spend the money on a direct fit Moser 12 bolt.
    If you pay $1500+ for this rear end, and put $1000 into it, plus the money to clean it up...Is it worth it?
  5. Rosster
    Rosster Veteran Member Gold Member
    547
    262
    Mar 1, 2020
    It’s not a 3.55, 3.73, or 4.10 so value is probably $1000-1500 if it has been updated with lower gears and posi. For $2500 you can get a brand new 12 bolt from moser. If it’s all still stock, $750-$800 would be it’s worth due to costs to upgrade it.
