'70 12 Bolt Rear End Yoke Torque Specs
Discussion in 'Transmission & Driveline Topics' started by clm69z28, Dec 5, 2021.
  1. clm69z28
    clm69z28 Veteran Member
    350
    10
    Oct 29, 2011
    encinitas ca
    Can someone confirm the torque spec for the 12 bolt rear end u joint straps? I have seen various suggestions of 15-20 lbs., but does anybody have the definitive answer?
  2. badazz81z28
    21,330
    1,543
    Alabama
    Tight, Can you even get a torque wrench in there?
  3. clm69z28
    350
    10
    Oct 29, 2011
    encinitas ca
    Sure, you just have to roll the car a little to get at all of the bolts. The concern is if you over tighten the bolts and crush the trunion caps. I can’t find it in the AIM or the service manual.
  4. Mitch_Z
    Mitch_Z Member
    41
    10
    Mar 31, 2007
    Detroit, MI
    From the 1970 Chassis Service and Overhaul Manual Camaro Supplement.
    Propeller Shaft "U" Bolt 14 ft. lbs.
  5. badazz81z28
    21,330
    1,543
    Alabama
    You can't crush the caps by overtightening the bolts. The caps sit flush on the yoke.
  6. clm69z28
    350
    10
    Oct 29, 2011
    encinitas ca
    Mitch_Z, I think that spec is for the u bolts, not the strap bolts. TY anyways.
  7. Mitch_Z
    Mitch_Z Member
    41
    10
    Mar 31, 2007
    Detroit, MI
    Very good. The AIM for UPC G84 (Rear Axle Positraction) says 12-17 Lbs Ft
  8. clm69z28
    350
    10
    Oct 29, 2011
    encinitas ca
    Mitch_Z, thanks. what page is that on, I looked but somehow missed it.
  9. clm69z28
    350
    10
    Oct 29, 2011
    encinitas ca
    I went out in the garage and checked my AIM again. That one page I must have missed ten times. Good to know that I haven't totally lost it yet.
