70-72 Ss Emblem Template
Discussion in 'Original Drivetrain Topic' started by THNDER, Sep 25, 2009.
  1. THNDER
    THNDER Veteran Member Lifetime Gold Member
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Guys, I need your help...I had a really nice template made up for correctly drilling for the SS emlems and eng size emblem, but I have misplaced it, and my body guy wants to drill the holes before he paints the fenders. Thanks in advance for your help. Mike:bowtie:
  2. THNDER
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Gary S.? Anyone? Mark Lenhard?
  3. Battmann
    Battmann Veteran Member
    708
    Sep 12, 2007
    North Chili, NY
    not sure if you are looking for just the information or an actual template so i hope this helps.
  4. THNDER
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Battmann, thanks for the reply...I have the assembly manual, with that page, but I found it a little confusing. I figured out the (0) reference but was unable to conclude what the (15) reference point is? I was hoping someone had an SS car with the original drilled fenders apart, and could make me up a template from the existing factory deilled holes. The fenders that were on my car, were not the originals, and the SS emblems looked like a 2 year old located and drilled the holes. Not even close. My other SS car is assembled and the emblems are bolted on from behind. So I am in a pickle...the painter wants to paint, but not before the correct holes are drilled. Thanks Mike
  5. COPO
    20,533
    2,262
    On your assembled car, you can remove the lower bolts from the fender and the shroud bolts and swing the lower part of the fender outward enough to get your hand in there and remove the nuts. This is the way I reinstalled my Z28 emblems using the nuts.
  6. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    Mike, I can make you a template from one of my cars if you still need it.....
  7. DarrenX33
    DarrenX33 Veteran Member
    982
    May 23, 2005
    Illinois
    I cheated. 3M emblem tape. Who knew? :)
  8. THNDER
    1,765
    Mar 18, 2000
    O'fallon, Mo
    Guys, thanks for the helpful hints and replies. Dennis Thomas has contacted me, and has exactly what I need. Thanks Dennis!!!!
  9. dkatap
    dkatap Veteran Member Lifetime Gold Member
    313
    Oct 23, 2001
    Central IL
    Mike, went out UPS today. Glad to help.
    Dennis
  10. CamarosRus
    CamarosRus Veteran Member
    8,545
    148
    Feb 16, 2000
    Auburn,WA (between Sea & Tac)
    Dennis Thomas, Been a good friend to myself, Mike Steitz and countless other restoration enthusiasts.
    Owns a LEGENDS awarded 71 Z-28 amongst his ongoing collection.
    Best regards to Dennis, always!!!!!!!!!!!!!!!
