70-73 Camaro Deluxe door panel repair question
Discussion in 'Interior Restoration' started by lapedr, Apr 11, 2018.
  1. lapedr
    lapedr Veteran Member Gold Member
    666
    23
    Jan 28, 2003
    Pembroke, GA
    Does anyone make a replacement or something close for the inner plastic rails located underneath the top of deluxe door panels. These are the ones that crack in 3 or 4 parts, and are stapled to the inside of the panel.
  2. 70lt1z28
    4,207
    965
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Not that I'm aware of. You may try contacting Just Dashes as they do restore these door panels. Maybe they have a part they will sell.
    I ended up using JB Weld epoxy on mine. I took a file and feathered the cracked edges out and blended the epoxy well into the good plastic. It seems to be effective.
  3. 70 SS/L78
    2,900
    139
    May 5, 2005
    Rockford, MN
    Last I heard Just Dashes gets around $1500 to restore a set of Deluxe door panels, probably more now.
  4. 70lt1z28
    4,207
    965
    Oct 3, 1999
    Yeah, that's about what they quoted me. And when they are done, they don't have the fake stitching. That was the deal killer for me. Not sure what they do if your die-cast metal part is pitted like most are.
  5. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,689
    898
    May 21, 2014
    Hutto, TX
  6. allenga
    allenga New Member
    Aug 24, 2019
    Anyone got any pics showing how they repaired this plastic upper door panel.
  7. badazz81z28
    20,314
    1,325
    Alabama
    Is it the same plastic that used in 78-81 top rail panels?
  8. allenga
    allenga New Member
    Aug 24, 2019
    Yes I think they all have the plastic top panel
  9. badazz81z28
    20,314
    1,325
    Alabama
    If that’s the case I would hunt down a more easier to find 78-81 door panel to get the plastic rail.
