70-73 Floor Pan Plug Help
Discussion in 'Body Restoration' started by geoman, Feb 16, 2021.
  1. geoman
    geoman Veteran Member Lifetime Gold Member
    2,023
    Jul 4, 2001
    Brandon, FL
    Are the plugs in the rear floor pans (round) just behind the front seat metal or rubber?? Not sure what happened to mine but I am close to finish the floors and seam sealing. Any help is appreciated.
  2. Scott51
    Scott51 Veteran Member
    730
    104
    Jan 2, 2012
    New Zealand
    Metal from the factory but a 1” rubber plug will also work
    geoman likes this.
  3. geoman
    2,023
    Jul 4, 2001
    Brandon, FL
    Thank you... I will keep looking on the shelf.
    I don't see where anyone sells the metal plugs but I do find the rubber. Seems like that is the only metal plug I cant find reproduced.
    Thanks again! Mike
  4. spinedoc
    spinedoc Veteran Member
    251
    16
    Jan 19, 2001
    Erie, PA USA
    I am looking for the correct plug as well. I would like to find a metal one if possible, but would take a rubber one. Do you have a link to the rubber ones?
    I so have some smaller round ones I think may work?
    Does anyone have a couple sets of these laying around you might be able to spare for us?
  5. BillyDean7173
    BillyDean7173 Psychopathy Red
    2,759
    934
    May 21, 2014
    Hutto, TX
  6. Rustbucket350
    Rustbucket350 Veteran Member
    986
    66
    Sep 4, 2013
    Oviedo, Florida
    I reused the best ones I had and deleted one with a patch I made to repair the toe board area. They aren't necessary unless you're planning to keep it original.
