70-73 LED tail lights with amber turn signals
Discussion in 'Rader Classics' started by Lrader99, May 18, 2013.
Thread Status:
Not open for further replies.
  1. Lrader99
    Lrader99 Veteran Member Lifetime Gold Member
    894
    Sep 18, 2005
    NW Georgia
    Designated turn signals are amber for a few reasons:
    -Amber is extremely easy to identify as turn signal/hazard when brake lights are lit.
    -Amber turns are required in EU.
    -Turn signals are required to be amber or red. I prefer Amber.
    If you tell me exactly what you are looking for I can accommodate you.
    I can do lights in the following styles: each light has inner and outer lights.
    Terminology:
    LH/RH inner lights (contains inner and outer leds)
    LH/RH Outer lights (contains inner and outer leds)
    -Dual park/Brake (outer LEDs park/ Inner ones are brake) contains no reverse. All 4 lights have the same function.
    -Park/brake & turn/rev (outer lights(inner brake, outer park) Inner lights(inner reverse, outer turn signal(amber)))
    -Park/Brake/ Turn & Brake/Turn/Reverse (outer lights(inner park, outer brake/turn), inner lights(inner reverse, outer brake/turn))
    I think I have answered all of your questions. LED kits do not come with lenses. They are separate.
  2. sceld71
    sceld71 Veteran Member
    1,067
    Nov 9, 2005
    Plain City, Ohio
    I can support these. They look really good, good job.
  3. airtimehocutt
    airtimehocutt Veteran Member
    209
    Aug 13, 2010
    MS
    Which style did u get? I am leaning towards dual tail/stop. I may try to add some type of reverse light later. That sequential turn looks interesting also
  4. airtimehocutt
    209
    Aug 13, 2010
    MS
    All red colors
  5. Lrader99
    894
    Sep 18, 2005
    NW Georgia
    I can give you dual turn/brake/park and give you reverse on the inboard lights. reverse would be white but I can do all the rest in red.
  6. airtimehocutt
    209
    Aug 13, 2010
    MS
    Which looks better at night. Park lights in outer ring or inner ring?
  7. airtimehocutt
    209
    Aug 13, 2010
    MS
    How does this work? Can u use the outer ring for park and brake/turn ?
  8. Lrader99
    894
    Sep 18, 2005
    NW Georgia
    I will use the outer ring for brake and turn, the inner ring for park and I will take a portion of the inner section for reverse. The inner sections are actually 2 separate sections combined into one.
    All 4 outer sections will be brake/turn, a portion of all 4 inner sections will be park, the other portion inner sections will be reverse on the inboard lights.
  9. airtimehocutt
    209
    Aug 13, 2010
    MS
    How does that look? Will both inner section be part reverse?
    Sorry for so many questions but I am fixing to order
  10. airtimehocutt
    209
    Aug 13, 2010
    MS
    After looking at ur website I think park outers look nicer. Can u make all inners brake/turn with rev mixed in all 4 inner sections? So I would have 4 stop/turn inners with 4 mixed in rev lights. Plus 4 outer park lights
Thread Status:
