Hoping to start troubleshooting this issue this weekend, so I decided to take a quick look today. The orientation of these pictures is with my head resting on the brake pedal looking back in the direction of the rear window. Yep, feet in the air and dreading having to climb back out. I noticed the dashboard hot/cold lever for the air, when moved, has a corresponding movement with what appears to be a broken bracket (first arrow on the left). I also noticed that the cable end (2nd arrow) isn't connected to anything. So, I'm taking a leap and believe at some point these two were connected. And assuming that's true, is it possible that this alone is the reason why my cabin is always blowing hot air? I was going to go down the actuator route, but could this equally likely be the issue?
Thanks for your help!
Thx for the tip. When I pulled the control unit out, I found a part that connected the cable to the door that controlled the heat flow into the cabin broken. Couldn't find the part anywhere so I decided to make it and just as I was going down that road, I found the part for sale! Always a good day when you can find a 52 year-old part!had a similar problem like that with my 77 corvette and I cured that by installing a manual cutoff valve that I purchased from Home Depot.
