70 Z 28 engine squeal
Discussion in 'Troubleshooting & Diagnosis' started by 70RSZ28CAMARO, Aug 14, 2020.
  1. roeville
    roeville Veteran Member
    1,276
    116
    Oct 9, 2000
    SF East Bay CA
    Check that your harmonic balancer’s outer ring hasn’t shifted and is rubbing against the cover.
    dickeymoore likes this.
  2. Terrys75LT
    Terrys75LT Member
    31
    May 12, 2019
    I’ve had this happen before. It turned out to be an exhaust leak. Sounds weird after trying everything else (belts, vacuum leak, etc). A simple manifold leak was the culprit.
  3. Sad Sack
    Sad Sack New Member
    26
    Jun 1, 2018
    Did you recently do a transmission replacement? If torque converter isn't installed right and not engaged properly, it will spin on the front pump and squeal and then it gets worse from there. Also check timing cover tang to make sure it isn't rubbing on balancer and check torque converter cover to make sure it isn't rubbing on flexplate.
  4. tom3
    tom3 Veteran Member
    13,458
    1,021
    Aug 1, 1999
    ohio
    A three foot piece of garden hose, one end at your ear, other end as a microphone. Usually get pretty close to the culprit.
