'70 Z-28 Manual Steering
Discussion in 'Original Drivetrain Topic' started by Mulsanne Blue, Jul 10, 2013.
  1. Mulsanne Blue
    Mulsanne Blue Veteran Member
    234
    Mar 31, 2009
    Goshen, Indiana
    My '70 Z originally had manual steering and I'm trying to gather parts. The only part, according to the parts book, that I'm not sure about or have ever seen come up for sale is the pitman arm. If I'm reading the books right, the number should be 6.859 3964877, http://www.gmpartswiki.com/getpage?pageid=86765. Can someone check the cast number on their original set up to confirm?
    As for the box, what should the turning ratio be? I found a dated 5679142 box, but I'm not sure if the ratio is correct.
    Appreciate the help. Scott
  2. Gary S
    24,131
    1,639
    The Z28 manual steering box had different gears inside it than the other Camaro boxes. Z28 box was 4.1 turns lock to lock. Non-Z28 manual box had 6.2 turns. The casting numbers on the box don't identify the gears inside.
    As a comparison, the power steering box was 2.3 turns lock to lock, so you can see that any of the manual steering boxes are slugs compared to power steering boxes.
  3. FlaJunkie
    6,451
    258
    Mar 24, 2001
    Rockledge, Florida
    From my rebuild. Pics are worth...
    My arm is a part listed for a power steering car. I have never changed it; I need to investigate this further.
    Does anyone have a pic of the 3964877?
  4. DCL70
    DCL70 Veteran Member
    1,687
    59
    May 5, 2007
    The South of N.H.
    I have one in my collection that is just like the one in FlaJunkie's photos.
    Casting #'s:
    Saginaw logo
    "13"
    "5679142"
    "113" (113th day of 1970)
    "B1320" stamped on pad (132nd day of 1970)
    Cover:
    "7802287"
    "CBC"
    "T"
    Pitman arm:
    "3864881A" and "GMT3"
    Dave
  5. FlaJunkie
    6,451
    258
    Mar 24, 2001
    Rockledge, Florida
    Dave, do you know what yours was used on? That pitman arm seems to be one for the power steering box.
  6. Gary S
    24,131
    1,639
    The original arm on my 70SS with power steering is 3964881. It appears to be just slightly under 7" in length.(I can't get an accurate measurement with it installed).
    I don't know how long the manual steering arm should be.
  7. frankz
    frankz Veteran Member
    2,125
    27
    Aug 24, 2009
    Illinois
    The quick ratio manual uses the longer pitman arm.(7")
  8. DCL70
    1,687
    59
    May 5, 2007
    The South of N.H.
    I bought the steering box at a swap meet. You are correct, the 3964881 Pitman arm is listed for P/S.
    My 1970 Chev. Parts Catalog (Oct. 1970) lists the following Pitman arms in Gr. 6.859:
    3964881 - 70 Camaro w/P/S
    3964877 - 70 Camaro exc. P/S
    My 1972 Chev. Parts Catalog (Jan. 1972) lists the following:
    3964881 - 70-71 Camaro w/P/S
    3964877 - 70-71 Camaro w/Sp. H/Per.(350)(exc. P/S)
    3964851 - 70-71 Camaro (exc. Sp. H/Per., P/S)
    Dave
  9. mgs1971
    mgs1971 Veteran Member
    226
    Jan 11, 2009
    CLEMSON, SC.
    I will not be reusing any of the manual steering stuff from my 71 if you are interested.
    Mike
  10. Smokin'Joe
    Smokin'Joe Veteran Member Lifetime Gold Member
    906
    153
    Aug 14, 2008
    Texas
    While I believe mine to be original to the car ( I have no way to assure that it is ), My car is an 07E Built SS/396 with manual steering. I just checked and it has the 3964851 arm which is also the one referenced by Dave in the 72 Parts Catalog.
    I will try and get some pics of it and the box.
    Also, I don't remember exactly, but awhile ago I was speaking to someone and they said the manual pitman arm was one of the harder pieces to locate in steering components.
