70 Z washer bottle
Discussion in 'Camaro Questions' started by ralph amitrano, May 7, 2020.
  1. ralph amitrano
    ralph amitrano Member
    96
    Dec 15, 2017
    What am i missing, on the righr side of the bottle i'm missing something to attach the bottle to can thumbnail (11).jpg you tell me what i'm missing thanks if it maters my car is a Van Nuys.
  2. Green hornet
    Green hornet Veteran Member
    1,859
    386
    Oct 11, 2015
    North Bay, CA
    If it a 70 the fender should have a sheet metal area built into it to accept the washer bottle. The fender may have been changed at one time with a non 70 fender or an aftermarket 70 fender without the washer bottle area.
    dave@ztech likes this.
  3. COPO
    18,931
    1,264
    70 factory fender with original washer jug.
  4. tom3
    tom3 Veteran Member
    12,600
    613
    Aug 1, 1999
    ohio
    I replaced the fenders on my 70 way back when and I made a plate to fill in that area, then drilled and installed the tank in the correct spot. Never had fluid in it, not used but looks nice.
  5. ralph amitrano
    96
    Dec 15, 2017
    Do you know where can I get the filler piece or have one made .
  6. 70lt1z28
    3,698
    758
    Oct 3, 1999
    Beavercreek, Ohio, USA
    No one makes just the filler piece to add to the angle cut fender. You will have to fab one up yourself or possibly a member here will send you one cut from a real 70-76 fender. It depends on how original you want it to appear. Another way is to use the bracket and bottle from a 1969. Also you may note that the bottle in COPO's photo has a square lower left corner. This was a 1970 only version. Part number 3961557. Later versions on Camaro's had a 45 degree miter on this corner. This bottle was also on truck's into the 80's sometime.
  7. bodymanbill
    bodymanbill Veteran Member
    1,501
    998
    Feb 1, 2007
    South Park Pa
    12F9C151-C465-4A38-95B8-76BB3CE5F45D.png 7EC354AB-D347-411A-9CEA-20A2BCE481C9.png My NOS fender shown here that i had edged in in red that i was going to use on my other car. I was lucky enough to have the original fenders on my car when i got it so I cut off that section and welded to my NOS one, wish I would’ve thought about making a template back when i did it.
    BillyDean7173 likes this.
