70 Z28 Clock to Oil Pressure Gauge Swap
Discussion in 'Interior Restoration' started by Tony P, May 26, 2020.
  1. 73RATTYZ28
    73RATTYZ28 Veteran Member
    516
    36
    Feb 23, 2001
    White Plains NY USA
    The reverse oil pressure gauge from Camaro central is odd. My brain Just couldn’t Deal with it. Daniel told me it was a discounted version he built for them. I swapped it out for the regular sweep in the ammeter spot that you can get from him if you ask. Direct fit and gets rid of the potential fire hazard. Mine fried out years and melted both wires. He also rebuilt my clock for Much less than the price of a new OER clock. I now have every gauge on my dash working and got rid of the all too common Auto meter pod in the console cubby and really cleaned up interior. Even put led dash lights so I can see the gauges at night.
  2. twestrup
    twestrup Veteran Member Lifetime Gold Member
    253
    135
    Aug 22, 2018
    St. George, Utah
  3. BillyDean7173
    BillyDean7173 Veteran Member
    2,409
    770
    May 21, 2014
    Hutto, TX
    I had him put a voltmeter in my cluster and get rid of the ammeter for the same reason. I replaced the clock with the oil gauge. If you swapped out the ammeter for an oil gauge but kept the clock, what gauge did you get rid of? Temp, fuel, or (I assume) volts? There's only room for three small gauges and the clock or am I missing something?
  4. 73RATTYZ28
    516
    36
    Feb 23, 2001
    White Plains NY USA
    I don’t have a volt meter so I have fuel and oil pressure on the left and temp and clock on the right
    BillyDean7173 likes this.
  5. 70lt1z28
    3,953
    871
    Oct 3, 1999
    Beavercreek, Ohio, USA
    Sorry to the OP if I have moved this too far from the original topic, but has anyone had a concern with running the oil line into the interior? I had a friend that had the nylon line break on his Corvette (it was 50 years old!) and it made a hell of a mess. Been thinking a gauge isolator may be better? Install the isolator in the engine compartment and run the air side of the line through the firewall into the interior?
    https://plastomatic.com/ggme-details.html
  6. COPO
    19,622
    1,705
    My Stewart Warner nylon oil line has been fine and I installed it in 1981 in T with the OEM sender and away from the heat. The vacuum gauge line is also good. Maybe Stewart Warner used a heavier gauge nylon. No problems here.
  7. 73RATTYZ28
    516
    36
    Feb 23, 2001
    White Plains NY USA
    Daniels gauges are electric so no worries there.
  8. hd_cat
    hd_cat Member
    37
    Sep 6, 2013
    United States
    I have used the C-10 mechanical gauge since about 1987, yes, the hole in the lens bothers me, but a gauge is much more helpful than the idiot light. I do use both, the light and the gauge. The car sits for long periods, so I crank the engine over until the idiot light goes out, then turn on the fuel pump and start the engine! I say go for it! You can find used truck gauges and NOS truck gauges for less than the cost indicated for the oil pressure gauge above. I used the clock delete plate to mount the gauge.
  9. Bob Schadlick
    Bob Schadlick New Member
    Sep 1, 2013
    salem, NH
    Are those 712 door panels available to buy and also the wood grain shifter plate?
  10. john Gialanella
    john Gialanella Veteran Member
    354
    16
    Oct 15, 2008
    Bloomfield N.J.
    Any members who are going to change to oil pressure form Amp gauge or clock, do not buy Camaro central's version. It is crap. It is not their fault, but company making them. The more expensive one is much better. I sent back the one from Camaro central.
    John.
